I have a 3 prong cord I'm going to install in an amp; it has the international style color coding and an extra wire that appears to be the shielding twisted and tinned. Is there something I'm supposed to do with that when I'm installing or should I just snip it off?
3 prong cord installation
Only special power cords have shielding. International? OK, so brown, blue, and green/yellow? The green yellow goes to chassis, the brown and blue are your mains supply.
If it really is a shield, then just connect it to chassis as well.Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostOnly special power cords have shielding. International? OK, so brown, blue, and green/yellow? The green yellow goes to chassis, the brown and blue are your mains supply.
I believe that extra wire could be a strain relief of sorts. But definitely meter that cable to the plug to be certain.
@Jazz P Bass - I took some pictures; I hope they show up. I don't think I've posted pictures before. I'm not sure, but I think I got this cord from Mojotone.
@Enzo - When I saw that extra wire on this cord, I went to check out 2 other cords that I have; one of them does have shield, but it has been trimmed down flush with the outer plastic insulation. Am I going to have a grounding problem with that cord?
@Tone Meister - What do you mean by "meter" the cord? How do I do it and what should I be looking for?
+1 to strain relief. the pics are a little blurry, and I cannot see how exactly the bare wire enters the cord, but the gauge size on the strands is telling. I'm sure you could land it to a point inside the chassis (ground or not) and anchor it securely.
If you can, check resistance from that lead to each of the others. If no continuity between that and any other, it has purely mechanical properties.If it still won't get loud enough, it's probably broken. - Steve Conner
Since you already have it, and to boot it does show continuity to ground, IŽd also connect it to ground on its own.
I *guess* shield in some power cords is there as an extra step avoiding SMPS hash from radiating all around, by using said power cord as antenna.
So if you have it, use it.Juan Manuel Fahey
Originally posted by J M Fahey View PostSince you already have it, and to boot it does show continuity to ground, IŽd also connect it to ground on its own.
