question for the gurus: why GZ34 (or monst tube rectifiers) max smoothing cap 60uf?
  • question for the gurus: why GZ34 (or monst tube rectifiers) max smoothing cap 60uf?
    Hi All,.
    I don't understand tube physics (yet!), anyone know why tube rectifiers have a fairly low max capacitor design value? E.g. GZ34 one sheet said max 60uf.
    Mike
    The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
    An uncharged cap looks like a short circuit to the rectifier until it has a charge on it. The larger the cap, the more current it takes to charge it. If you install too large a cap, it tries to draw too much current through the rectifier tube.
      Thanks Enzo!
        Yep, and I over simplified it a little, each half cycle of rectified current recharges whatever has leaked out or been used from the caps. The larger the cap, the higher the potential charging current while in use.
