I guess I'm a sucker for punishment. After many months, I've finally gotten my V1032 up and running. Even added a Top Boost. Now I'm on to the next challenge - installing the "big head" distortion booster. Yes, I know I could just use a pedal in front of the amp, but I'd like to get it all on board.
So, after getting all the parts, I built the circuit on a little PCB and added it to the V1032. No surprise, it's not working. None of the voltages are where the spec says they should be. At least I was able to confirm that the relay functions, so I can rule that out.
Starting at the top, the DB circuit expects a +20V source which is not available in the V1032, so I used a 100R/680R voltage divider on the 27V (25.6V in my amp) source. I read 19.6V where I should have 20V, close enough, but the voltages in the rest of the amp are thrown - the 31.5V drops to 30.8V, the 25.6V drops to 22.7V, and the 16.6V drops to 14.8V. Should I be using a higher resistance voltage divider?
Beyond that, none of the other voltages read as I would expect - Q401C reads 9.8V instead of 1.65V, Q402C reads 10.9V instead of 4.5V, Q402E reads 0.6V instead of 1.5V and the positive side of C404 reads 14.3V instead of 10V. I'm not sure how much of this might be due to the voltage divider issue.
Any advice? Thanks, Mel
Here's the V1032 circuit. In my amp, I removed the e-tuner.
vox-berkley-ii-v1082-1032.pdf
Here's the V1141 Beatle circuit where I got the distortion booster schematic.
Here's my PCB layout. Inelegant, but I'm using a RadioShack board I picked up on clearance.
Finally, here's the amp itself. The DB circuit replaces C1, and I made a jumper so I could use the posts on the board. The white cable clip runs to ground to shield the leads to the DB board. Also, you can see the Top Boost pot in the background where Input 3 had been.
