introducing delcano 45 by scott amplification
  • introducing delcano 45 by scott amplification
    ok so its only a 5f4
    http://pg.photos.yahoo.com/ph/scole9.../ph//my_photos
    Just a 5F4?
    The 5F4 (and the like) is still one of my favorite tweed Fender amps....
    I think they are right at the very start of what we think of as modern sounding, vacuum tube guitar amps.
    Bruce
    Mission Amps
    Denver, CO. 80022
    www.missionamps.com
    303-955-2412
      How did you make the board? Did you make your own template, or buy one?
        5f4 board
        i made the board myself, since this amp is a reverse layout like a jtm45, i drew the board with a cad program, printed it out, taped it to the board material and drilled. i ordered the eyelets from mouser. i counter sink the bottom side of the holes, i used a large center punch to flare the eyelets into place. the center punch and the couner sink are the same angle. the board material comes from mcmaster carr. if you need a drawing of the board let me know.
          What type of material is it? How much did you pay? I'm interestede in making my own boards, because I keep getting crappy boards from mojo. I think I would like to go with black though. I checked out that mcmaster carr site lots of good stuff there, thanks for the info.
            board material
            heres the part number 8557K152, its 9 dollars, 1/8 thick, 3 inches wide by 24 inches long, enough to make two boards.
