Mixed auto/fixed bias in amp
Originally posted by GainFreak View PostI was looking at this Leslie 147RV reverb amplifier and noticed that it has simultaneously a fixed and kind of cathode bias or something.
So what's the purpose of that RC combo in the cathode?
What is notable, the OT secondary is part of the self-bias network, providing a feedback loop around the output tubes & transformer. AFAIK this is unique to Leslie amps.
Aside from the involvement of the OT secondary, the RC combo works as in all other self biased amps.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostI don't see the "fixed" bias, no negative voltage supplied to the 6550 control grids.
Justin"Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Well, from a manufacturing perspective, the addition of the cathode bias components allows tubes with a wider range of characteristics to be "plug and play" due to the self adjusting nature of cathode bias compared to straight fixed bias. You probably get more power output this way than just 100% cathode bias. Also a bit of protection should the bias supply fail.
Some silverface Fenders used a similar arrangement, as did some versions of the Vox AC 50.
Originally posted by octal View PostLeo must be looking at the bottom amp, not the top amp.
Now that I see the separate reverb amp, I concur with your #4. 7189 is a beefed up EL84. If you have one of these and can't easily find 7189's, you could put a trim pot in series with R28 & dial down the bias current to a level EL84 would get along with. Might be a thought to replace C23 with a higher voltage rated cap if the necessary bias voltage rises beyond -15V.This isn't the future I signed up for.
...you could put a trim pot in series with R28 & dial down the bias current to a level EL84 would get along with...
[ATTACH=CONFIG]42845[/ATTACH]
Mainly it just provides a convenient way to monitor the cathode current.
I don't understand why even in modern amps most manufacturers are reluctant to put 1 or 10 Ohm resistors in each tube's cathode like couple of more cents will destroy their budget.
They don't bother because such a very tiny percentage of people who buy their amps will even know what it was for, let alone how to use it.Education is what you're left with after you have forgotten what you have learned.
Here's a funny thing. Recently a friend brought an ENGL for retubing. They bothered to use zero Ohm resistors (jumpers) to connect all power tubes' cathodes to a common ground bus but didn't bother to put 1 Ohm resistor (maybe worth the same couple of cents).Last edited by GainFreak; 03-22-2017, 07:42 PM.
Originally posted by GainFreak View PostAccording to some Mesa schematics like DC3, F30 etc they are running EL84s at approx the same conditions unless they use some beefed up version.This isn't the future I signed up for.
From what I know about EL84 they can take higher plate voltage but that doesn't apply for the screens. The specs show up to 400V if dissipation doesn't exceed 8 Watts so max plate voltage and less than max screen voltage looks like a survivable situation although it doesn't add much to the resulting power.
