Originally posted by Leo_Gnardo
View Post
First tube amp build: Fender Deluxe AB763 style amp (no reverb).
The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
After much toil, decided on Nichicon capacitors for the first build As long as I don't blow it up, can always put in pricey ones later. Total bill for all electrolytics is about 11.00 from Mouser (plus shipping). I will tack on the Hammond transformers since they are a Hammond distributor, and prices seem about what everyone else is charging. That leaves the other bazillion parts to buy.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by potatofarmer View PostAn easy way to come up with a BOM would be to print the schematic and label each component with a letter and number... R1, R2, C1, C2, etc. When you assign it a number, make a note of it in a spreadsheet. For ease of ordering later, make sure to also note anything special about it. "Label | Value | Notes" or something like that. Once you've entered it in your spreadsheet, highlight it on the schematic you've printed out.
I suggest using a spreadsheet because later on when you go to order you can sort the list by the value column and quickly see that you need, say, sixteen 1-meg resistors. I'll typically add a couple columns for, say, "Vendor," and "Vendor Part #" which helps greatly to have in advance. Even though it happens to me every time, it seems I'm never fully prepared for a Mouser order and within 5 minutes of ordering parts I'll remember at least a dozen 5-cent parts that I need. Also with vendor information included, you can make nifty pivot tables.
For capacitors, make sure to get at least the same voltage rating, or better. A lot of coupling caps are rated to withstand 630V - this is fine.
For resistors, make sure to get at least the same wattage (power) rating, or better. If the schematic calls for a 1/2-W resistor, a 1W or 2W will also work just fine.
Also don't forget that you're going to need jacks, sockets, tubes, the tremolo optoisolator "bug", transformers, knobs, a footswitch, wire... all that stuff.
For vendors of general electronic components, I tend to use Mouser. It can be tricky learning how to navigate their site, but once you get the hang of it, it goes quickly. One nice thing about Mouser is that they include the value in the part number, so once you find a resistor you like in 220k, you can just replace the "220k" in the part number with "100k" and get the same resistor in a different value.
You're probably going to need to use multiple vendors though, and someone like Antique Electronic Supply is a decent place to start.
Building a clone amp is a balance of frustration versus cost. Or any amp, really; but with a clone you have the option of a fully compiled kit with all the parts and maybe even instructions. Simple to order, but higher cost. On the other end, you can spend hours hunting down each and every little part, and while your hair might fall out, at least you saved some money.
For a first build, you might want to save your "frustration budget" for actually building the thing. I'd recommend building a Champ kit, because they're great and quite simple. Or buy a little 5W tube amp (there are a bunch out there) and experiment on it. Oh yeah, look up the "AX84 P1 Theory Document" - that's a good start on learning what does what.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
wooh: http://www.tubebooks.org/Books/gray_...tronics_2e.pdf tough to trudge through this one.
Currently reading Merlin's book (awesome). Will get through both eventually.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by mikepukmel View Postwooh: http://www.tubebooks.org/Books/gray_...tronics_2e.pdf tough to trudge through this one.
Just looking through the TOC for the Applied Electronics text, I had flashbacks to Freshman physics. Big book, not in a year did every chapter get covered. Pick and choose. When you realize you need some of the earlier content (that was skipped) to explain the material you're reading, go back... or use the internet
IOW don't trudge, investigate!If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by eschertron View PostMerlin's book on preamps. Good one. I'm still waiting with bated breath for him to reissue the rest of the series.
Im alternating time on the Merlin book, as you say its awesome. yeah, hope he gets time to do a power amp book.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Total cost ...
Still just over $1,000.00. Probably will end up in the 1,150 range.
Transformers + cabinet + speaker + tubes, not much can do to get those costs down.
Surprised at how fast the pots + knobs + misc added up.
Got the order list down to 3 orders total:
1) Hoffman - eyelet boards for cap board, bias board, most of the resistors, some caps, tube sockets, some wire.
2) Mouser - major items are transformers and choke. Also ordered a few misc discretes (some ceramic caps, power resistors)
3) Antique Electronic Supply. - Knobs, pots, misc hardware, tube set,
The only thing this doesn't cover is some mounting hardware, and hookup wire. Will probably order wire from Hoffman, but he's out of a few of the colors I want to use.
Thought by now I would be hacking out my favorite Jeff Beck tunes through this amp, but I haven't even ordered most of the parts yet. Hoping it will go together fairly quickly once the parts are in.
Found an awesome site:
https://sites.google.com/site/jmasterschematics/
this guy has redone many of the Fender schematics, READABLE! they are just great. I got a trial of acrobat, and annotated a few of the schematics (Deluxe, and Pro) with part reference numbers on all the caps and resistors and pots, so I can check for errors in my parts order list.
Got some tips from Merlin on reducing blocking distortion and 'farting out' on this amp, since its famous for that.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by mikepukmel View PostFound an awesome site:
https://sites.google.com/site/jmasterschematics/If it still won't get loud enough, it's probably broken. - Steve Conner
Should have done this first (some of you suggested before ), annotated a schematic with part id's, then wrote parts lists from that. Anyway, after hours of misery with a flaky trial version of Adobe Acrobat:
DeluxeAB763Annotated2.pdf
Went back through the web shopping carts Ive been working on for ages, found that the resistors I had in the carts were all low voltage versions. Fixed that. Also, upped the wattage on a few 100k resistors that feed plates, and the 2 dropping resistors on the cap board. Praying for the strength to type in the credit card and click "Submit order". today, so that at least I can get the pots, and tube sockets and transformers bolted in, and main board soldered up by next week.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Questions for the gurus: The smoothing electrolytic cap right after the diode on the bias board, is 25uf in the old (ab763) schematics. This cap value was raised a few times by CBS, in later versions "to reduce hum". I think the final version was 70 or 80uf. The GZ34 has a max capacitance rating of something like 60uf, but since this isn't inline with the GZ34, is it safe to use a larger cap here, 80uf or 100uf, whatever I can find?
In some later amps, all of the 100k resistors feeding the anodes in the preamp are higher wattage. Is it safe to up the wattage on these resistors, would this increase noise or cause some other problem?
The early amps, by the chassis images I could find, have a nice brass sheet under the pots that is bent to sit in the chassis, and heavy buss wire is soldered from this plate to ground points in the circuit on the fiberboard. I have read that the 'dissimilar metals' issue between the brass sheet and steel chassis caused corrosion in some amps. I have found thin sheet brass with teflon or some other insulator on one side. Just placing the teflon side against the steel chassis would make a very nice big capacitor, but what if I took my big weller and ran a few big solder beads right at the edge of the brass plate to the steel chassis to short the unintentional capacitance between this plate and the chassis would this work?The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by mikepukmel View PostThe smoothing electrolytic cap right after the diode on the bias board, is 25uf in the old (ab763) schematics. This cap value was raised a few times by CBS, in later versions "to reduce hum". I think the final version was 70 or 80uf. The GZ34 has a max capacitance rating of something like 60uf, but since this isn't inline with the GZ34, is it safe to use a larger cap here, 80uf or 100uf, whatever I can find?
preventing oscillation, instability, etc in new amp builds
I have been reading up, trying to understand causes of parasitic oscillation, and instability in tube amps. Lead dress comes up often. Bad tubes, bad discrete components, bad solder joints, bad shorting jacks. The article link below, a nearly open electrolytic cap caused problems that would be very difficult for me to diagnose on my own.
So, we should measure the values of all of the components, the best we can, before installing them in a circuit?
Amplifier Stability
The last bit on the article, the writer was diagnosing some problems with the amp, and found one cap was far off spec, nearly open ckt.The only good solid state amp is a dead solid state amp. Unless it sounds really good, then its OK.
Originally posted by mikepukmel View PostIn some later amps, all of the 100k resistors feeding the anodes in the preamp are higher wattage. Is it safe to up the wattage on these resistors, would this increase noise or cause some other problem?If it still won't get loud enough, it's probably broken. - Steve Conner
Originally posted by mikepukmel View PostSo, we should measure the values of all of the components, the best we can, before installing them in a circuit?If it still won't get loud enough, it's probably broken. - Steve Conner
