Results 1 to 9 of 9
Thread: Cream Plastic Humbucker Covers or Plastic Source?
    Sep 2011
    Minneapolis
    284
    I am looking for cream colored plastic humbucker covers. Mojo used to have them but no longer do.
    Anyone have any leads?
    Or, where could I source a thin cream colored plastic sheet to cut for humbucker inserts to use with open covers?
    All ideas appreciated.
    Old Timer
    Feb 2010
    Just south of Bawlmer, Merlin
    2,381
    Received: 95/1
    Given: 67/1
    From the Peanut Gallery
    Quote Originally Posted by jrdamien View Post
    Be careful what you wish for. Here are some "ideas":
    > I don't know why cream humbucker covers aren't widely available- unless it's just for lack of demand.
    For Gibson humbuckers, cream plastic covers aren't "historically correct"- but neither are black or white plastic covers.
    It's got nothing to do with the infamous DiMarzio trademark- which is for exposed cream bobbins.
    > In searching for material for DIY inserts, try color names other than "cream".
    The hue you are seeking might be called "tan", "beige", "almond", "ivory", "sand", "camel", "antique white", "cafe au lait", "Swiss chocolate"....
    > If you're going to go with open covers, there's no reason to limit the insert material to plastic.
    You might find other materials more interesting.
Name:	Creamery_Custom_Sweet_14_Gold_Silver_Foil_Pickup_Set_Gibson_PAF_Humbucker_Size.jpg
ID:	42892 Click image for larger version.
Name:	Creamery_Custom_Sweet_14_Gold_Foil_Pickup_Set_Gibson_PAF_Humbucker_Size_Custom_Covers.jpg
ID:	42893 Click image for larger version.
    > Formica and Wilsonart both supply free samples to "qualified parties".
    You might check them out for some tasteful, or tacky, possibilities.
    Formica® Laminate - Cafe
    High Pressure Laminate - Retro Renovation® Crème Caramel - Y0406
    Have fun,
    -rb
    EDIT:
    Found some "creme" polystyrene sheet on eBay.
    Different size sheets, all .080" thick, from the same vendor.
    Too thick for your application? Here's one example:
    STYRENE POLYSTYRENE PLASTIC SHEET .080" THICK 6" X 6" CREME COLOR | eBay
    EDIT2:
    Automotive plastic spray paint?
    Jan 2009
    591
    Schaller used to make them and probably still do.
    https://www.schaller-electronic.com/...kup-Covers.htm
    Cheers
    Andrew
    Sep 2011
    Minneapolis
    284
    Quote Originally Posted by rjb View Post
    The hue you are seeking might be called "tan", "beige", "almond", "ivory", "sand", "camel", "antique white", or....
    Have fun,
    -rb
    EDIT:
    EDIT2:
    Thanks for all that. The images are...good, but without a source for any of it...
    Yes, .080 is too thick.
    Jun 2008
    PDX
    174
    Formica is a great way to go. I have some on hand if you just need a little. If you need them cut, I can do that too. How many do you need? (This is for inserts)
    I haven't seen the cream plastic covers for a while. I used to have some.
    Roadhouse Pickups
    Sep 2011
    Minneapolis
    284
    Quote Originally Posted by the great waldo View Post
    Cheers
    Andrew
    They do. But, cost + shipping + spacing, etc...
    It is an option, though.
    Sep 2011
    Minneapolis
    284
    Quote Originally Posted by Magnut View Post
    It is. You have cream formica? I only need 2 but would buy more for down the road. I would need them cut and, if you're able, drilled.
    Old Timer
    Feb 2010
    2,381
    Received: 95/1
    Given: 67/1
    The available Formica patterns with "cream" or "creme" in their names are probably not what you are looking for.
    But 5"x7" samples of "Cafe" and "Desert Beige" in gloss finish are free for the asking.
    Formica Laminate Swatches - Samples
    Jun 2008
    PDX
    174
    @ jrdamien, is it a neck and bridge? What string spacing do you use? Drilled? If you mean for the poles, I will use laser to do the whole thing. I can do a few sets to help get you through.
    Roadhouse Pickups
  1. Cream humbucker plastic covers
    By buddha0709 in forum Pickup Makers
    Last Post: 12-30-2016, 03:41 AM
  2. Magnet Blade Bobbin Pickups, Built in plastic Humbucker Covers
    By big_teee in forum Beginner/ Hobbyist
    Last Post: 11-06-2014, 12:58 AM
  3. Black and cream plastic sheets
    By Zhangliqun in forum Pickup Makers
    Last Post: 05-21-2014, 01:32 AM
  4. Plastic mini-bucker covers...
    By fieldwrangler in forum Pickup Makers
    Last Post: 08-17-2012, 04:41 PM
  5. Which plastic for Plastic pickup covers
    By belwar in forum Pickup Makers
    Last Post: 11-21-2011, 06:58 AM
