Deluxe Reverb 5U4 problem
  • Deluxe Reverb 5U4 problem
    I have a 68 deluxe reverb. Recently, while replacing all tubes, I tried to power up and blew a fuse.I backed up to the old tubes and replaced the tubes one at a time. The amp works with the old 5u4 but not with either of 2 new ones. What should I look for?
    hallo. hope this can help...
    go to this site: http://www.geofex.com/
    in the left upper corner you will find "tube amplifier debugging page". then go to "pops fuse"...
    hope this helps. greetings from vienna
    oh, and be carefull, if you don't have experience with repairing tube amps, read this first: http://www.aikenamps.com/SafetyTips.html
