Results 1 to 20 of 20
Thread: Clamping diodes to limit crossover distortion?
    Jan 2014
    Chiraq
    1,002
    Received: 213/5
    Given: 247/1
    7
    Is this the function of the 1N5062 diodes in the attached schematic? They are labeled CR27, CR30, CR31, CR32 in the schematic.
    can anyone explain what these diodes do and why these diodes are chosen for this task? Is this so you can bias the amp really cold and limit or eliminate crossover distortion?
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,787
    Received: 1,661/7
    54
    They connect the grid to cathode, essentially to ground. The grid is negative, so they are reverse biased usually. If the grids go positive more than the diode junction drop, they conduct. They prevent the grids from going positive.
    Jan 2014
    Chiraq
    1,002
    Received: 213/5
    Given: 247/1
    7
    If grid voltage is under 100v why is an 800v diode chosen?
    Jan 2014
    Chiraq
    1,002
    Received: 213/5
    Given: 247/1
    7
    What would be the scenario causing grids to go positive? Shorted coupling cap from PI?
    I was too anxious to see what would happen so I clipped in some 1n4007s and my output signal looks exactly the same. I guess these are not here for the purpose of limiting crossover notch at clipping
    I also just tested the amp while monitoring bias voltage and bias voltage does not change either with 1N4007 installed or not installed. Meaning, bias voltage is 51V at idle pretty much up until clipping, then going far into clipping it goes to about -61V.
    I am curious because of an old email I am re-reading about the model T. The author says
    Fender recommends 60mV per side, or 30mA cathode current per tube at the schematic B+ of 489V, which equates to a plate current of probably 27mA and idle dissipation of 44%! Interestingly enough, biasing this cold does NOT produce a crossover notch on the output. It's quite clean. There is a load of NFB in the power stage. And when the amp is driven into clipping, you don't see a bias shift notch develop because there are clamping diodes to ground from the power tube grids. Point is, the amp is NOT sensitive to bias.
    I guess I should ask the person who actually said this, but I figured someone on here would know the answer. How is it so that this amp is not bias sensitive?
    31,787
    Received: 1,661/7
    54
    Nothing to do with crossover distortion. What would cause the grids to go positive? Signal level exceeding the bias voltage. Bias at -40 and send a signal with 50v peaks and you have 10v of positive grid.
    Feb 2010
    11,608
    Received: 1,516/23
    Given: 3,837/11
    22
    Do you have an audible defect? Crossover distortion is usually noticeable at very low signal levels, like the decay of a note. If you are seeing a crossover notch on the scope at full power clipping, I'm not even sure you'd be able to hear it as such.
    Supporting Member
    Staffordshire UK
    3,693
    Received: 434/1
    Given: 408/2
    18
    Quote Originally Posted by nsubulysses View Post
    Maybe a beefy diode has been used to reduce the risk of the diode becoming collaterol damage in the event of an internal tube short, eg g2 to g1?
    Re
    I don't think that makes sense, as the silicon diodes are just in parallel with the tube diodes formed by g1 being (momentarily) biased positive to its cathode; so they may make bias shift under overdrive a tiny bit worse, if anything.
    ...How is it so that this amp is not bias sensitive?
    I can't see why it should be any less bias sensitive than other similar amps.
    Jan 2014
    Chiraq
    1,002
    Received: 213/5
    Given: 247/1
    7
    Audible defect is slightly nasally raspy high end tone that is a little grating and unpleasant.
    I am messing with a few things because my amp has a bit of crossover distortion beause the screen supply sags a lot at full volume. It's a long story, there's a few threads about it. I have 590V B+ so my screen supply has 1K/20W dropping resistor in series with it so the screens don't die.
    Anyway, that's why I was researching clamping diode phenomenon to lessen crossover notch. The Fender Sunn model T came to mind. and the infamous Chuck H mod, but I believe it's only for cathode biased output. Anyway.
    I been trying a few things
    I tried 470pF cap paralleling V1 plate resistor but it made the tone a little too subdued, although also less shrill in the high end like I was desiring.
    What really helped was increasing my NFB resistor from 150K to 200K and also decreasing my bias feed resistors from 220K to 150K. The sound is tighter since the bias drifts less and cleaner/clearer sounding with less high end weird nasty sounds, I guess mostly from increasing NFB resistor
    I am messing with a few things. Perhaps the diode clamp thing is on the wrong path
    I can post a pic or two of the output if anyone is interested to see
    Feb 2010
    11,608
    Received: 1,516/23
    Given: 3,837/11
    22
    Yes, pictures would be helpful.
    Jan 2014
    Chiraq
    1,002
    Received: 213/5
    Given: 247/1
    7
    The names of the files are the RMS output into 4 ohm load, ie. 47.png means 47W output into 4 ohms
    I would say the crossover notch starts to show at about 45w output.
    I should also add that when in my last post I said how upping my NFB resistor and decreasing bias feed resistors helped, I meant it helped the sound. It did not change the look of the output on a scope.
    May 2010
    Sioux Falls, SD
    6,186
    Received: 1,110/1
    Given: 880/1
    16
    What is the actual bias current? I don't see it mentioned here? If I were seeing crossover distortion, I'd check that first. I see there are shared 1 ohm cathode resistors already installed.
  12. #12
    Jun 2006
    California, USA
    3,559
    Received: 160/0
    Given: 92/1
    17
    Those scope traces are showing an inordinate amount of crossover distortion even for a full power output signal. In my opinion, it is much more than normal and I suspect that something basic needs to be corrected. I.e. this is not a candidate for any special crossover distortion fixing modification.
  13. #13
    Feb 2010
    11,608
    Received: 1,516/23
    Given: 3,837/11
    22
    Could you post your actual build schematic?
    Also, did it look/sound like this before you dropped the screen voltage? (or were there other changes made at the same time?)
  14. #14
    Jan 2014
    Chiraq
    1,002
    Received: 213/5
    Given: 247/1
    7
    Bias is 26mA at 584Va. However. my matched quad has two power tubes doing 22mA at idle and one doing 28mA and one doing 29mA. I have a strong and weak tube on each side of push pull.
    I'll get back with more info soon
  15. #15
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    11,735
    Received: 1,861/23
    Given: 1,453/35
    26
    I donīt see crossover distortion at all (which is a low level phenomenn) but bias shifting (not the same by a country mile) caused by halfwave rectification.
    The diode involved is G-K and the peak voltage storage capacitor is the coupling cap.
    A perfectly normal phenomenon, has been there since the Pyramids were built, IS PART OF THE TUBE SOUND, and nobody worried about it until armchair designers bought scopes, started hearing with their eyes, assimilated this dynamic waveform kinking to static underbiasing and tried to fight this perfectly normal (and important, and useful) phenomenon desperately, by all means.
    Including nonsense "biasing tubes by dissipation", for Godīs sake.
    Of course, I am in a Forum, what do I expect?
    Iīm trying to convert nobody, just do as you please.
    Itīs interesting to remember that designers of Tube Emulation circuits (think Pritchard, Peavey Transtube, GK and a few others, including yours truly), introduce this kind of dynamic waveform kink (and half a dozen other things) *on purpose*
  16. #16
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    15,069
    Received: 2,114/4
    Given: 2,403/0
    30
    Either the forum or my computer circumstances aren't offering "like"s right now. Just want to say that Juan gets one from me.
    The diodes seem to be there for the reasons stated above. As to the voltage spec., possible typo? My system, which isn't actually my mod but a small addition to and a formula for using the Paul Ruby mod, actually clamps the negative voltage swing immediately after the tube is driven into cutoff so the coupling caps can discharge when no useful signal is happening. It works a treat and some amps that use el84's benefit from it because they can sound so buzzy and fizzy compared to other tube types under the same overdrive levels. I don't use it for all amps and never with big bottles for the reasons Juan stated. Unless you have a fizzy el84 amp there's really no need to implement the "chuck h"/Paul Ruby mod. I think you would do better to reduce screen sag by any means (smaller filter, diode drop instead of resistor, branched PS instead of a series rail resistor, etc.) and heat the bias a bit using tubes that can handle it. That's where I would start. Not mentioned yet, but I don't think that amp is exactly revered for it's OD tone. It's more of a loud and cleaner sort of amp I think. Trying to make it into something it's not is like racing with a dump truck. It has four tires like a race car, but it's not a race car.
  17. #17
    Jan 2014
    Chiraq
    1,002
    Received: 213/5
    Given: 247/1
    7
    You guys are great but unfortunately I still don't understand exactly what the diodes from control grid to ground do, only for the fact that I see no difference on the scope screen and I hear no audible difference with 1N4007s clipped in. Is keeping positive voltage off the control grid good because it limits bias excursion or because if signal level exceeds negative bias supply level it causes the PI coupling caps to charge and causes blocking distortion?? Or something else? SOrry I know it's been explained a couple times but I don't totally understand. I am referring to the diodes 1N5062 in the model T schematic in post 1.
    Anyway, this is basically what i'm working with.
Name:	144 power:output.jpeg
    Chuck, your mod has made you legendary. now you will have to explain it over and over to people who don't quite understand it. Maybe this amp isn't a good candidate and it's a look inthe wrong direction anyway. ALso, you are thinking of the 1970s model T which is loud and clean with KT88s and ultralinear output. I'm thinking of 1990s model T made by Fender which is just a modern high gain amp with channel switching and clean and gain channels, 100W with 6L6s
    This amp sounds good. Just trying to perfect it.
    Power tubes are 6CA7 so .026 x 586V = 15.23W / 25 = 61% plate dissipation (sorry juan)
  18. #18
    31,787
    Received: 1,661/7
    54
    You see no difference with and without? OK, in your tests, are you driving the tubes with enough signal level to drive the grids into conduction? As protection devices, they only do anything when conditions exist that require the protection.
    Like seatbelts in your car, normally trhere is no difference wearing or not wearing them. it is only when you run into something that they determine if you explore the face/windshield interface.
  19. #19
    Jan 2014
    Chiraq
    1,002
    Received: 213/5
    Given: 247/1
    7
    I will have to test when I have the amp back open again but I guess probably not. Just guessing though. Perhaps my -51V bias voltage is a lot to overcome, if I'm thinking about it right. Would these diodes be more useful in a circuit that only has a -30v bias voltage ?
  20. #20
    31,787
    Received: 1,661/7
    54
    How many amp circuits have you seen? How many had this particular diode thingie? They saw fit to add them, but the vast majority of amps don't have them. Don't obsess over it. I don;t see anything else special about this amp, amps all tend to be very similar under the skin.
  1. Ampeg B3 with crossover distortion
    By spy in forum Guitar Amps
    Last Post: 01-27-2016, 04:22 PM
  2. Crossover distortion scope shots and questions
    By waspclothes in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-28-2014, 06:37 PM
  3. Crossover distortion with my 6L6 from Eurotubes
    By tpawlowskis in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-31-2012, 10:09 PM
  4. Does 5E3 have crossover distortion?
    By lowell in forum Theory & Design
    Last Post: 07-09-2009, 09:04 AM
  5. Crossover distortion
    By lowell in forum Build Your Amp
    Last Post: 07-03-2009, 11:03 AM
