There are 4 green LEDs on the output PCB. When this amp is working are they all lit, all off, half lit? I asked Mackie and they weren't sure. Go figure.
Mackie SRS1500
Does the amp work? Both channels? SOme LEDs are not for indicating, they are there for the voltage drop. What if there were no LEDs? How would you proceed then? DO it that way now.Education is what you're left with after you have forgotten what you have learned.
I have a Mackie SRS1500 I'm trying to repair. The output is at -60VDC to the speaker, with no load and no input signal. I have noticed some other very strange voltages. For example at Q24 leg 1 is 69V, leg 3 is 68V, but leg 2 is -63V. But Q17 has -64V on all 3 legs, and Q19 is -60V all 3 legs. I've checked just about every componate and replaced the suspects with factory parts, namely: C9,Q3, Q9, C5, Q11. Curiously running up the variac, D26 flashes faster and faster as the voltage increases, and a clicking sound, appears to be inside C5, an box cap.
I tried to include the .pdf but no luck even though I have it on this computer. Someone clue me in here?Attached Files
