New model Fender Bassbreaker 15 repair
  • New model Fender Bassbreaker 15 repair
    Fixed one of these new models yesterday.
    Looks like fender are in competition with Peavey and ENGL to produce
    the world’s hardest amp to service!
    The amp had a shorted EL84 but when I replaced them the same socket made the new valve (sorry , Tube) draw excessive current.
    Very hard to even see the component side of the PCB but managed to meter the 2 240E 5W cathode resistors, one of which measured 70 Ohms.
    I marked all the interconnect leads and removed about 30 screws, lots of cable ties to remove the PCB.
    Found the cathode resistors paralleled with 47uF and a 35V 5Watt Zener, one of which had become a resistor.
    They probably thought that this very fault condition would not have enough current to damage a 5W clamping zener?
    Removed both Zeners, re assembled the mess and all working properly again.
    The repair took 4 hours!
    The customer came from Albany 30 miles away so I did the repair in front of him.
    No schematics are around for this model yet (PR 3034)
    Bluh! But glad you got it fixed!
    Justin
      Wow! I've been waiting for the Bassbreaker repairs to drop, and am not surprised it's so difficult to get under the main PCB. You are a madman for taking that on with a customer watching! Great job. Nerves of steel.
      Wondering if the Bassbreaker 45 is as much of a PITA.
      http://amps.monkeymatic.com
ID:	845266Repaired an ENGL Savage 120 last week, now that amp is a PITA!
          I agree. It's unparalleled.
            I see what you did there, Dave H.
              I love that PCB presentation of solder-side-first. Like, nope, talk to the hand.
                The worst part was the interconnecting lead terminations were all covered in silicon goop and many of them need to be removed and desoldered to lift the PCB.
                  Anyone have a schematic for the Bassbreaker 007? Got one in. Treble is acting like a volume. Checked all caps leading to the Treble pot and none are a dead short.
                    Has to be something in the tone stack, not necessarily the treble components.
                    The stack is typical of all Fenders.
                      Did you CALL Fender and ask if they would provide it?
                        Yes, they would not.
                          May not be the answer but heres some links for thought on the issue at hand.
                          Tone controls acting like volumes! Need Help!
                          Vintage Amps Bulletin Board ? View topic - '59 Bassman Treble down = Volume Up.
                          Hope they help.
                          nosaj
                            Thanks, sorry for the dual thread I'll stick with the other one that I started.
                            http://music-electronics-forum.com/t44526/
                              How much takes for straight on four full working hours for a 500 bucks amp? Half?
                              "If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
                              streameast
