Results 1 to 8 of 8
Thread: Sovtek 5Y3GT?
    Supporting Member
    Aug 2009
    Near Nashville
    778
    Received: 157/1
    Given: 142/1
    11
    Sovtek 5Y3GT?
    I'm building a 5e3 style amp, and bought some Sovtek 5Y3GT rectifiers. ubuyguitars.com has them 2 for $9.99. Now I'm reading online that they are not the same as old 5y3's. Should I not use one in a new amp? Can I mod the circuit to compensate for the difference?
    Sep 2011
    Pace, FL
    3,304
    Received: 1,159/102
    Given: 160/36
    12
    Quote Originally Posted by dmartn149 View Post
    When you build it put only the 5y3 in and check voltages to see where it's at.
    nosaj
    Old Timer
    Chill-Ville, VA
    3,254
    Received: 730/6
    Given: 1,440/10
    18
    Rumour has it they were simply "not-quite-GZ34s." Probably not a problem if you're using JJ 6V6s. But if it's for a new build, yeah, check what it puts out, then mod to your heart's content - at that price, dayum.
    Justin
    Supporting Member
    Aug 2009
    Near Nashville
    778
    Received: 157/1
    Given: 142/1
    11
    Thanks guys. They still have 282 of them in stock, still 2 for $9.99 too. I guess I'll build then check voltages, then come back here for more advice.
    Old Timer olddawg's Avatar
    Dec 2007
    La Jolla CA, Hanalei, Kauai
    3,020
    Received: 317/0
    Given: 34/1
    16
    This is the same guy that I got those cheap VHT 18 watt amps from with the Australia PTs for cheap. Both the 18 watt and the 36 watt chassis use that tube and sound/work fine. He's 10 minutes from my house.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,431
    Received: 1,998/7
    55
    And never forget this: these are only guitar amps, not precision lab gear. CLose is good enough.
    Feb 2010
    12,009
    Received: 1,782/24
    Given: 4,584/11
    23
    Just because no one directly mentioned it, the voltage is usually higher with the Sovtek than with 'proper' 5Y3s.
    If any of your caps or tubes are running close to the rated max. voltage limits, you would not want to use this as a replacement.
    Supporting Member
    Aug 2009
    Near Nashville
    778
    Received: 157/1
    Given: 142/1
    11
    Thanks everyone. I know "close is good enough" I also know that higher voltages from my local power company is the norm nowadays.
    I got these 5y3 tubes, a chassis (aluminum $13) and a PT (Chinese $5) He had hand wired 5e3 circuit boards (probably Chinese) I think they were $20. I procrastinated and missed out on that one.
  1. 5y3gt on 6.3 ac?
    By cbass in forum Guitar Amps
    Last Post: 01-06-2014, 12:59 PM
  2. New JJ 5Y3GT out in the wild...
    By echuta13 in forum Tweed Builders
    Last Post: 11-12-2012, 12:32 AM
  3. Sovtek 5Y3GT--good tube?
    By Rhodesplyr in forum Tubes (Valves)
    Last Post: 10-29-2010, 01:54 PM
  4. Sovtek 5Y3GT and Sovtek 5V4G?
    By catnine in forum Theory & Design
    Last Post: 07-06-2009, 02:43 AM
  5. 5Y3GT data sheet?
    By bluefoxicy in forum Theory & Design
    Last Post: 05-24-2008, 01:54 AM
