I'm sure many will think this is a question that we all should know the answer to so I may be the only one. I have a MMRD50 with 6l6's and wondered if el34's could be substituted for them with out significant changes? Thanks in advance for your patience!
6l6 to el34 tube swap?
Plus
Check that there is a link between pins 1 and 8 on ALL of the output tube sockets. This to connect the EL34 suppressor grid to the cathode. 6L6 doesn't have a suppressor grid so doesn't need that connection. A lot of amps will have that link in them just so that EL34 or 6L6 can be used. If your amp does not have that link then you will need to add it.
Cheers,
Ian
Ok! Thanks all of you for the great information. Since the MM is stock as I bought it in 82 I think a good work around would be just find a nice 40 or 50 watt el34 that was designed that way.
BTW Gingertube, what is "Rat Coffin" type and do they reduce current/voltage?
"Rats Coffin" type is slang for the white ceramic block style power resistor.
Like this one:
https://www.digikey.com.au/product-d...0KW-5-ND/18703
They introduce some screen compression and limit screen power dissipation.
Cheers,
Ian
Wow, you know, all these names are colorful and fun. In all my years, I never adopted a name for them, I still call them rectangular ceramic resistors. Kinda trips off the tongue, donit?Education is what you're left with after you have forgotten what you have learned.
Originally posted by Enzo View PostWow, you know, all these names are colorful and fun. In all my years, I never adopted a name for them, I still call them rectangular ceramic resistors. Kinda trips off the tongue, donit?This isn't the future I signed up for.
