Results 1 to 11 of 11
Thread: Algorithms for music: real-time parameter modification
    May 2013
    189
    Received: 3/0
    Given: 9/0
    Hi everybody,
    I don't know how many people use rack fx these days, and how many dig into them to catch new sounds, but I would like to share with you what I obtained as complex waveforms to control parameters on my fx units.
    Basically, as you probably know, rack fxs have the possibility to assign some parameters to CC midi signals, or voltage on specific inlets, or volume pedals and so on. Lexicons (at least my lexicons) limit them to 5 per each unit.
    On Mesa Boogie Triaxis you can assign any of the stored values (gain, mid, lows, highs, volume, etc...) to an external information, in order to change it while playing.
    Same can be applied to the parameters of all rack fxs compatible with CC signals.
    Some of them are just a 1 bit signals (0-63 and 64-127), some have full dynamic on the 128 values.
    You can then change in real time the shape of the chorus, the decay of a reverb, the pan, etc...
    After being in contact with Professor John Chowning of the Stanford University, the inventor of the FM modulation on the synths to emulate the real sound of the instruments, I came out with some algorythms to change in real time the parameters of my rack fxs.
    Here below you can find the code.
    I've done it in matlab to speed-up the plots, but I've intentionally used the same commands that can be used in Arduino, that is the platform I'll use to send commands to the fxs.
    Code:
    % #1 funzione per Chorus con AM ed FM
    fc = 0.29; % Carrier Freq (Hz)
    fm = 0.085; % Modulating Signal Freq (Hz)
    m = 9; % Modulation Index
    t = linspace(0, 10, 2^14); % Number of samples
    y = -0.45*sin(2*pi*fc*t*0.96) + 0.45*cos(2*pi*fc*t - (m*sin(2*pi*fm*t))) + 0.1*cos(2*pi*fc*t*2.8);
    subplot (3,2,1), plot(t,y);
    % #2 funzione per panning
    fc = 0.69; % Carrier Freq (Hz)
    fm = 0.23; % Modulating Signal Freq (Hz)
    y = - 0.5*sin(2*pi*fc*t - (m*cos(2*pi*fm*t*0.618))) + 0.5*cos(2*pi*fc*t*2.8 + (m*sin(2*pi*fm*t*0.618)));
    subplot (3,2,2), plot(t,y);
    % #3 funzione per psycho-flanger
    m = 1; % Modulation Index
    y = - 0.5*sin(2*pi*fc*t - (m*cos(2*pi*fm*t*1.32))) -0.5 + abs(cos(2*pi*fc*t*1.32 + (m*sin(2*pi*fm*t*0.618))));
    subplot (3,2,3), plot(t,y);
    % #4 funzione per dimensione riverbero
    m = 19; % Modulation Index
    p = 0; %numero del plot
    y = - 0.6*sin(2*pi*fc*t - (m*cos(2*pi*fm*t*1.32))) + 0.4*cos(2*pi*fc*t*3 - (m*sin(2*pi*fm*t*1.32)));
    subplot (3,2,4), plot(t,y);
    % #5 funzione per chorus lento
    fc = 0.069; % Carrier Freq (Hz)
    fm = 0.023; % Modulating Signal Freq (Hz)
    y = - abs(sin(2*pi*fc*t - (m*cos(2*pi*fm*t*1.32)))) + abs(cos(2*pi*fc*t*3 - (m*sin(2*pi*fm*t*1.32))));
    subplot (3,2,5), plot(t,y);
    % #6 funzione per chorus lento
    fc = 1.29; % Carrier Freq (Hz)
    fm = 0.385; % Modulating Signal Freq (Hz)
    m = 18; % Modulation Index
    t = linspace(0, 20, 2^14); % Number of samples
    y = cos(2*pi*fc*t - (m*sin(2*pi*fm*t*0.26))) ;
    subplot (3,2,6), plot(t,y);
    Has anyone done something similar to his rack?
    Attached Files Attached Files
    May 2013
    189
    Received: 3/0
    Given: 9/0
    Same concept can be applied to Rhythms too (see attached recent research).
    May 2013
    189
    Received: 3/0
    Given: 9/0
    The Matlab code I've developed to see the effect of each parameter in 25 different plots is the following:
    Code:
    % Plot funzioni con AM ed FM
    for fi = 0.1:0.04:1.06;
    p = p+1;
    y = cos(2*pi*fc*t - (m*sin(2*pi*fm*t*fi))) + 0.1*cos(2*pi*fc*t*2.8);
    subplot(5,5,p), plot(t,y);
    end
    To switch from the [-1,+1] range of the plots to the [0,127] midi range, you can use the map function in Arduino: https://www.arduino.cc/en/reference/map
    May 2013
    189
    Received: 3/0
    Given: 9/0
    This is what the previous lines plot. I like to plot the parameters this way, in order to understand how they'll affect the function.
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    It's nice of you to share what you have learned and refreshing to see something new
    May 2013
    189
    Received: 3/0
    Given: 9/0
    Thanks nickb,
    I would also like to see if this can lead new people to experiment, and see new results.
    May 2013
    189
    Received: 3/0
    Given: 9/0
    Well, the basic code is really simple.
    I modulate the frequency of a sine or cosine wave by varying the value of the radiants during the time:
    Code:
    This can be splitted in:
    Code:
    y = cos(2*pi*fc*t)
    That is nothing else than a simple cosine wave of the carrier frequency fc.
    Then I modulate the radiants of the funcion, so I change the speed of the radiants, so the frequency.
    Code:
    It's a frequency modulation of the carrier frequency fc at the modulation frequency fm.
    The amount of modulation is set by the parameter m.
    This is the very basic one, then you can do whatever you want:
    - square waves by adding nth order harmonics at the amplitude 1/n;
    - absolute values of the sinewaves;
    - odd roots of the sine waves;
    - triangular waves;
    - sawtooth waves;
    - etc...
    May 2013
    189
    Received: 3/0
    Given: 9/0
    For example, do you want to do an AM modulation of a FM modulated sine?
    Code:
    y = cos(2*pi*am*t) * cos(2*pi*fc*t - (m*sin(2*pi*fm*t))) ;
    Where:
    - am is the amplitude modulating frequency;
    - fm is the frequency modulation frequency.
    Do you want to modulate only from 0 to 50% of the total swing?
    Code:
    y = 0.5*cos(2*pi*am*t) * cos(2*pi*fc*t - (m*sin(2*pi*fm*t)))
    Otherwise you can use the map function in Arduino and change the destination range to 32-96 omitting the 0.5.
    Best way, is to keep the full range on the midi and reduce the range when assigning the midi cc to the effect parameter. This way you do not reduce the resolution in the transmission of the parameter while obtaining the same result.
    May 2013
    189
    Received: 3/0
    Given: 9/0
    Here you can find a recent video showing what I was working on at the time I started the thread (it's not me but the concept is the same):
    https://www.youtube.com/watch?v=UuK-w2xHTZU
    Dec 2009
    Devon, UK
    2,912
    Received: 158/0
    Given: 142/0
    I suppose you could add some pots to your Adruino based controller to vary selected parameters. You could also have the ability to save these setting to a patch. Perhaps add a pedal or two and the built it into a stompbox for some real time effect variations.
    May 2013
    189
    Received: 3/0
    Given: 9/0
    Yes Nick, actually the pedalboard I'm designing for my two racks has three external foot controllers:
    One can be assigned to a ldr based wah (I think you have seen my tests on those) or to some parameters through midi cc commands (like the morphing on my Lexicon Vortex, one of the very few rack units that can do that). The other two have always cc purposes. It gives really great options on old units (like Lexicon MPX1), and even LPX1 and 5 becomes great real innovative effects.
  1. First time post, first time building cabinets
    By csparks75 in forum Cabinetry
    Last Post: 02-27-2018, 11:20 PM
  2. Akai lpd8 overview (synth knobs parameter)
    By Junglehood in forum Music Electronics
    Last Post: 01-28-2016, 03:46 PM
  3. Real Time SPICE Simulation
    By jazbo8 in forum Theory & Design
    Last Post: 03-22-2014, 05:57 AM
