Results 1 to 15 of 15
Thread: behringer a500 amp repair
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    hi all i have a behringer a500 to repair one channel appears to be going into protection,
    when i switch on with a signal on the channel and just advance the volume you hear a little bit of sound but as you advance the volume you hear plop and then no sound,
    On checking i find that the +15volt line goes to 0volts on lowering the volume it will restore to 15volts. this is measures at the junction of D4/C1 on channel 1 im guessing something it drawing too much current on the 15volt line when the volume is raised so the voltage is being droped on R4 but what could cause that. and it also does the same with no signal on the input but with just raising the volume. schematic attached.
    Behringer-A500-power-amp.pdf
    Feb 2010
    10,206
    Received: 353/1
    Given: 692/0
    So if you are using both channels, when the bad side cuts out, the good side keeps working?
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    yes
    yes the channel 2 works all the time the channels are basically completely separate, the only thing they share is the transformer
    1 Not allowed! Not allowed!
    Feb 2010
    10,206
    Received: 353/1
    Given: 692/0
    Isn't the power supply common to both sides of the amp?
    It's not really clear from the schematic, but I only see one supply for +/- 17V, it sounds like you are just losing the connection to the +15V on the one amp.
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    no each amplifier is fed from an ac winding on the transformer then they have a set of diodes which produces +-50 volts the 15 volts is derived from that supply via R4 D4 C1, the 17volts is just for the front bargraph leds.
    ill upload a picture of one on the amps.
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    Feb 2010
    10,206
    Received: 353/1
    Given: 692/0
    Have you checked for excess voltage drop across R4 during fault condition? How does it compare to voltage across R4 when working?
    If not a big change (or if decrease rather than increase) then it is not an excess current problem but a connection problem.
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    volt drop
    the voltage is all dropped across R4 so am fairly sure it is excess current somewhere.
    Feb 2010
    10,206
    Received: 353/1
    Given: 692/0
    Any IC's getting hot when in fault mode?
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    ok problem solved replaced ic 1 and 2 not sure which one failed but they are on the back of the board so easy to change both while the board was off the heatsink,
    amp now working
    difficult to get to while the board was mounted so not easy to fault find on them, there are no obvious shorts on them
    New Member
    May 2017
    4
    Mellowamoya, I have the same exact problem. Could you provide which ic you replaced it with? I know that it's a mount 4580 ic but dont know what size it is. I have read on many forums that njm4580 is a good replacement but they come in different sizes. Could help?
  12. #12
    Feb 2015
    trinidad WI
    33
    Received: 1/0
    hi,
    i replaced with a 4558 smd ic it works without any problem the 4558 can replace the 4580.
    NJR NJM4580E-TE1 from mouser.com
  13. #13
    New Member
    May 2017
    4
    Quote Originally Posted by mellowamoya View Post
    hi,
    Thank you so much for your help.
  14. #14
    New Member
    May 2017
    4
    hi,
    Okay. I took the a500 ic chips out and measured with a calibur which measured a little bigger then what you recommend, 5mm x 5mm x 1.6 mm. Whereas, the njr3580e-te measured 3.9mm x 5mm x 1.5mm; however, I have order it. Hope it fit. Will update later.
  15. #15
    New Member
    May 2017
    4
    hi,
    Got the chip yesterday but installed today and it perfect. Now, bumping it for testing. Thank you very much bro!
  1. Behringer DDX3216 - Trying to repair, please help!
    By fznuk in forum Music Electronics
    Last Post: 09-09-2018, 01:32 PM
  2. Replies: 2
    Last Post: 04-17-2017, 05:04 PM
  3. Behringer HA903 - Headphones amp - Repair
    By Cafon in forum Other Amps
    Last Post: 01-10-2014, 01:36 PM
  4. Behringer KX1200 loud hum only repair help please!!
    By fausto in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-30-2012, 04:58 PM
  5. Behringer XY1200 Keyboard Amp repair?
    By doc_drop in forum Other Amps
    Last Post: 06-23-2009, 11:01 AM
