peavey dual piezo broken pieces(????)
  • peavey dual piezo broken pieces(????)
    I have a broken peace of electronics that is installed on my peavey 112hs floor monitor....it is a dual horn piezo tweeter and there are two gray rectangular pieces (1 inch x 1/4 inch high with wires on each end connected to the - and +) crisscrossed and soldered. They are marked FB2 SAB. Does anyone know what these are and how can I get a replacement? thanx Billy Hurd
    The item in question (FB2 SAB) is a 'cement resistor'.
    The value is 560 ohms and the power rating is 3 watts.
      The whole dual horn unit can be bought here
      Dual Driver Piezo Horn Tweeter T-1150DP
      [CODE]http://www.simplyspeakers.com/replacement-speaker-tweeter-t-1150dp.html]Dual Driver Piezo Horn Tweeter T-1150DP[/CODE
      Dual Driver 5" x 11" Piezo Horn Tweeter Peavey Type 70777107, T-1150DP
        And the resistor can be found here: MCPRW03WJP561B00 - MULTICOMP - Through Hole Resistor, Metal Film, 560 ohm, Axial Leaded, 3 W, ± 5%, MCPR Series | Newark element14
          560 ohms sounds way too high.
          Usual values run from 10 to 100 ohms tops, with 47 ohms being a favorite, often recommended by many Companies.
          This is a common wiring diagram:
            Seems a good place to refer to a document from Pulsar Developments ..
            The range formerly manufactured by Motorola
            Pulsar Developments Ltd - Piezo / Ceramic Speakers
            Application Note
            Pulsar Developments Ltd - Piezo Tweeter Application Note
              I always found it cheaper to replace the motors on the dual piezo rather than replace the whole thing. I could buy the single unit KSN1005 and remove its motor and replace the ones on the dualie. The motors are the same.
