I know this may a long shot, but I am in need of Eden WP-100 schematic. The tube isn't conducting, so even just the front end section would be great. Thank you.
Eden Navigator WP-100
This is all I could find, but maybe one of the preamps is the same.
http://music-electronics-forum.com/a...en_various.zip"I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
Originally posted by Randall View PostI know this may a long shot, but I am in need of Eden WP-100 schematic. The tube isn't conducting, so even just the front end section would be great. Thank you.
nosaj
edit: Have you contacted EDEN for a schematic?Last edited by nosaj; 05-23-2017, 12:27 AM.soldering stuff that's broken, breaking stuff that works, Yeah!
This unit is a rack mount preamp, so those amp schematics won't help. The plate voltages are both at 112v, and the signals are getting to both grids, but no signal on the plates, and I can't get to see much else as the tube socket and it's components are partially hidden under the top board. I do have about 30v on the girds however. I'd like to see a print to know what is going on. I have an email request out to Eden, so far no response.It's weird, because it WAS working fine.....
50V at the cathode does not sound real standard, what kind of resistors are the cathodes connected to?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by mozz View PostI don't think you will get a reply, the Eden forums say "no schematics, don't ask"
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
AFAIK those are fake tube preamps, simple cathode followers inserted in the signal path so they can state "signal goes through a tube stage".
So, like on any cathode follower, NO signal on plates (which go straight to +112V rail).
If anything, inject signal on grids (both triodes are in parallel) and look for it, same level, on cathodes.
Marketing BS.Juan Manuel Fahey
Navigator WP-100 schematics attached
Just in case, I found I had the WP-100 Navigator Schematics in my files. They were cut into pieces, so assembly req'd, but all appear to be there.
WP100 - Full Schematics.pdfLogic is an organized way of going wrong with confidence
