Fishman SA220 active pa speaker
  • Fishman SA220 active pa speaker
    Good morning to you
    I have a Fishman SA220 pa speaker with excessive noise, Coming from the pre amp
    This seems to be a common fault as what i read from the net
    But nobody has posted the cure
    I need a map for this unit, as this would be the quickest way rather than tracing the fault
    I have contact fishman directly but i don't expect a reply
    have a good day
    BBB
    i Thought i would give an update. The whole front panel is available from JHS in the uk for £107 inc tax etc
    this is a trade price.
    i was told that Fishman wont give out the schematic
    while confirming that the pre amp is at fault. I noticed that treble pot for channel 2 was not right. Cleaned it and it was better. I tapped it and the noise went away. Replaced the pot all good
    BBB
