Results 1 to 12 of 12
Thread: Rokit 6 g2 repaired ?
    New Member
    Jun 2017
    2
    Angry Rokit 6 g2 repaired ?
    One of my g2 Rokit 6 speakers started to buzz loudly. Fixed the buzz but
    it now has intermittent HF tone at power up.
    Background:
    Rokit 6 g2, playing loudly and all of a sudden started to buzz like hell..
    I powered it down, popped out the amp and connected the HF and LF outputs
    to a dummy load and looked for the source of the buzz. I could see that the
    signal coming from the preamp board looked ok. Voltages looked OK as well.
    however there was this large square wave looking signal on the HF speaker
    output. Took a look at the power supply's for the TDA's.
    I found that the +/- 15V supply had a few bad caps. The 47uf caps on the
    zener references measured a high esr and were low capacitance as was the
    main 100uf cap. on the +15V side. C104 which was supposed to be 100uf/25V
    measured 9uf with an esr of 187 ohms ! The 47uf/35V cap on the zener ref for
    +15 measured 30uf w/esr 40 ohms. I replaced both 100uf/25V caps in the 15V
    supply and the 47uf/35V caps on the zener references.
    I replaced the caps and powered the speaker back on and sure enough
    it was dead quiet. No DC on outputs. Ran a signal through it, could see a
    nice clean waveform on the output, both lf and hf seemed fine.
    Packed it back up and played it for about an hour. Worked find, low vol and
    some pretty high volume to give it a good workout.
    Turned it off, came back about an hour later and when I turned it on I got
    a loud HF tone, not a buzz like before. I turned it on/off a few times. Each
    time the HF tone. wft ?
    Back to the bench. Off comes the back, power it up, works fine ..? I figure it
    could be a connection problem between the boards as some have pointed out
    this is a potential source of issues. I clean and re-seat the connection. Put
    the back on and try it again. Plays great, sounds great for several hours.
    Come back at night, power it on. HF tone again. Back to the bench, remove
    the back and the HF tone stops. I figure it has to be a connection. So I try
    best I can to get it to fail by moving the connector with no luck.
    Thinking cold solder I poke around on the board moving components gently
    but no joy.
    Question is... has someone had a similar issue and found what was causing it ?
    I checked out the Mute circuit, it seems ok. It's almost like something is
    oscillating .. It only seems to happen when the unit has been used for a while
    and turned off for a few hours. If I play it for an hour or so and turn it off and
    back on its fine. I hate the intermittent failure type problems...
    Old Timer olddawg's Avatar
    Dec 2007
    Carlsbad, CA and Kona, HI
    2,671
    Received: 45/0
    You didn't post a schematic but I have repaired a number of these types of biamped monitors. Generally the first cap that is going to fail and cause a huge buzz is the main power supply filter cap which is the biggest cap in the mess, usually a 4700uf, maybe as low as half that. These caps are usually mounted on a double sided board and buried in glue. You can cause a lot of intermitancies if you don't properly work the double sided boards using the cap leads as feedthroughs. I generally double the voltage rating of the caps if they wil fit.
    New Member
    Jun 2017
    2
    Thanks for the reply...
    The schematic is available on this site. The issue with my speaker was in the tweeter supply. There are two power supplies
    in the Roki 6. A +/- 15 runs the HF tweeter amp and preamp. This is where my problem was. I did check the large
    caps in the +/- 20 V supply. They measured fine. Lucky for me there wasn't much black goop anywhere on my board.
    The bad caps that caused the original buzz in my case were all in the +/- 15v supply. The speaker worked, but every
    few power cycles would have this high-freq tone and when I opened it back up it would stop.
    After cleaning and re-seating the connector between the pre-amp and power-amp sections, I'm happy to say I have had no issues
    (so far ) The speaker is dead quiet and works fine after about 10-15 power cycles and usage over the last few days.
    Quote Originally Posted by olddawg View Post
    Dec 2011
    Pretoria, South Africa
    678
    Received: 1/0
    Fistly remve all of the black glue on the boards. As much as you can. It can become conductive. It usually does.
    Stray Cap DrGonz78's Avatar
    Oct 2011
    Scottsdale, AZ
    1,794
    Blog Entries
    1
    Received: 56/0
    Given: 34/0
    Old thread but just saw a video on YouTube about this very issue that diydidi mentions. Horrible black goop that becomes conductive!! ugh!!
    Dec 2008
    Wernersville, PA
    12,354
    Received: 107/0
    Given: 31/0
    Ahh, the conductive 'Black Goop From Hell'.
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    I love the guy's disgust. "It's horrible stuff...... I don't like it."
    Dec 2008
    Wernersville, PA
    12,354
    Received: 107/0
    Given: 31/0
    The engineers probably spec'd one thing and the off shore manufacturer had a brother in law that had a similar product but 'oh so much cheapa'.
    Dec 2008
    Wernersville, PA
    12,354
    Received: 107/0
    Given: 31/0
    Dave is great!
    I love the one where he gets a low frame rate camera and can't decide what to do with it.
    "I know! Let's blow some shit up!".
    https://www.youtube.com/watch?v=9jDsNe_bmtE
    I'll bet he caught grief about all of the shrapnel on the deck.
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    Looks like fun..... blowing up caps. I worked at a pro audio store in the early nineties. They also had a couple bays for installing car stereos. We used to hook up the old car speakers to a variac to see what they'd take. Fun, but smelly.
    May 2010
    Sioux Falls, SD
    5,321
    Received: 265/0
    Given: 234/0
    Since we're already , another fun thing to do is put a CD in the microwave with all the lights in the room off. It looks like a little lightning storm. Probably not good for the microwave, but I haven't hurt anything yet.
  12. #12
    Old Timer
    Chill-Ville, VA
    2,593
    Received: 136/1
    Given: 273/6
    3 seconds and pull it out, you can actually make some interesting art that way... And the microwave will make everyone's lunch smell like plastic for ever and ever and ever and ever...
    Justin
  1. Krk rokit rp10-3g3
    By mj108 in forum Schematic Requests
    Last Post: 06-05-2017, 01:31 AM
  2. KRK Rokit 6 G3 version 2 (RPG3V2)
    By diydidi in forum Music Electronics
    Last Post: 04-30-2017, 12:57 PM
  3. Marshall valvestate 8080 repaired?
    By zoblitz in forum Maintenance, Troubleshooting & Repair
    Last Post: 07-01-2015, 07:20 PM
  4. Repaired Amp Break in?
    By myque in forum Repair and Restoration
    Last Post: 01-07-2011, 08:38 PM
  5. Can a Tube Socket Be Repaired?
    By ENB in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-08-2008, 01:41 AM
