Ok, I managed to peel away some of that dried out cloth insulation and expose the break. can anyone tell me what that red coating is on the wire? Is it a type of insulation? How would I strip it? Sanding paper? Would it be ok to solder them together and shrink wrap them? That seems to be the simplest way to go about this. thanks
Marshall Major Blowing Power Fuse
Originally posted by cluster View PostThanks so much Leo. Could you please post links to the insulation you are referring to. It would be a great help.
Also, I was taking resistance measurements across the secondaries at the impedance selector and all my readings gave me 0 ohms. Is this normal? I would expect some resistance across some of these windings. Could this mean that there is a short in the secondary as well?
GE RTV silicone cement sold in nearly every hardware & home-center store. Handy 3.5 oz tube about the size of a large tube of toothpaste I expect will run you about CD$5. I used to use it in a hi-vacuum hi-voltage lab and it insulated well up to 25000 volts.
Heat shrink tubing, if you still have any open Radio Shack stores, they sell it. If any other electronic supply stores, they should have it too, in several diameters. Worst case you have to send away for it, Mouser has a nice selection, I prefer 3M polyolefin which they provide in a wide selection of diameters & colors in handy 4-foot or 6-inch cuts:
http://www.mouser.com/3M/Wire-Cable/...z0zp4dZ1z0vrwt
275 choices of diameters & colors, I'm sure you'll find something to suit your needs.
Red coating on your transformer wire is insulating lacquer. You can scrape away near the ends you need to splice, twist & solder then cover with a layer or two of heat shrink. For extra insulation you may want to coat that with a layer of RTV, let it dry then reassemble your transformer. Hopefully you'll have no further trouble from it. Whew, what an adventure.This isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostResistance of secondary (speaker) windings, a fraction of an ohm normally so don't worry if you read nearly short circuit.
Thanks so much. Couldn't have done it without everyone's help. Please tell me how and where I should apply this RVT cement? Thx
Originally posted by cluster View PostThanks so much. Couldn't have done it without everyone's help. Please tell me how and where I should apply this RVT cement? ThxThis isn't the future I signed up for.
Originally posted by Leo_Gnardo View PostFirst get those wires spliced. Easiest way is scrape the lacquer off, twist the ends & solder. You could wrap that with electrical tape or use a wire nut, but my way would be to cover that splice with heat shrink, heat & shrink that first layer. Then add a second & maybe a third layer. It's probably overkill at this point but I'd coat the splice with RTV, let it harden for a day, then reassemble. Here comes some smart guys to tell me that's going too far . . . just wait they'll show up any time now. So the RTV is optional. Use the remainder to seal any leaks in your bath or shower or roof or gutters, that's what it's really good for.
Thanks so much. Could you comment on this and would it be useful to put in my major? :
OUTPUT SPIKE PROTECTION
This modification involves taking three 1N4007 silicon diodes in series with the banded end connecting to pin three of your output tubes and the other end to ground. You use one on each side of a push-pull output. So for example, on a 100 watt Marshall the two tubes on the left, either pin three of either one of those tubes can connect to this diode to ground. And on the other side either pin three can connect to the other set of diodes to ground, as the tubes on either side are in parallel.
We use 1N4007 silicon power diodes which are effective in suppressing spikes at certain frequencies. These will not necessarily prevent spiking on all amps! There is a fast recovery or high speed diode which will suppress higher frequency arcing however these diodes have a very distinct disadvantage as they alter the tone of the amp! They make the amp sound muddy as they bleed off high frequencies from the output transformer! Trainwreck does not use these kinds of diodes because of their effect on the tone.
While the Trainwreck method does not eliminate spiking in every amp, it does not effect the tone at all. Every other method which will totally eliminate spiking will have a negative effect on the tone of your amp.
Another point to remember concerning spiking is that hot biased amps tend to generate more high voltage spiking than properly biased amps.
Originally posted by cluster View PostOUTPUT SPIKE PROTECTION
This modification involves taking three 1N4007 silicon diodes in series with the banded end connecting to pin three of your output tubes and the other end to ground. . . . .This isn't the future I signed up for.
So I spliced the primary wire and double wrapped it in shrink wrap. Put the OT back together and took some readings:
Primary winding:
end to end = 29.1 ohms
CT to left = 14.8 ohms
CT to right = 16.4 ohms
UL leads end to end = 11.5 ohms
CT to left UL = 7.4 ohms
CT to right UL = 6.7 ohms
All leads to ground = open (no resistance)
Does this sound right? Are there any other tests I should do before testing it with the PT. Would it be worth testing the OT with the battery method on the secondary?
Thx,
Joseph
Also, I'm considering replacing the can caps in this major but the 200uF cancaps are oversized. Modern cans are smaller. Does anyone know of way to modify the large clamps to accommodate the smaller cans? BTW, I know these cans are 47 years old. ESR meter was giving me a reading of .67 which should be good? Is it worth replacing these caps?
Just any update. I used a small transformer to deliver 7.4 VAC to the secondaries to test the windings and I believe it to be working well. Please check my work. 7.4VAC on the 16 ohm tap of the secondary resulted in 90.6 VAC across the primaries with an even 45.3/45.3 VAC from CT to each end. Seems like it's working. Might be time to wire it all up and put the amp on the Variac.
Just follow up... I did the math to calculate the OT's impedance:
90.6VAC/7.4VAC = 12.24 turns ratio
12.24 squared (impedance ratio) x 16 ohms = 2,398.4 ohms or 2.4 KOhms, which is dead on spec.
Next step wire it all back up and put it on the variac (no tubes) and hope she purrs....
Originally posted by cluster View PostAlso, I'm considering replacing the can caps in this major but the 200uF cancaps are oversized. Modern cans are smaller. Does anyone know of way to modify the large clamps to accommodate the smaller cans? BTW, I know these cans are 47 years old. ESR meter was giving me a reading of .67 which should be good? Is it worth replacing these caps?
Originally posted by cluster View PostAlso, I'm considering replacing the can caps in this major but the 200uF cancaps are oversized. - - - - - Is it worth replacing these caps?This isn't the future I signed up for.
Question: I don't have a speaker cab here to use as a load but I do have a 16 ohm THD hotplate with a load option on it. I don't intend to test it with tubes in. Would the hotplate be a good enough load to test the OT w/o tubes or should I wait to have the proper cab? If all goes well and I want to test/bias the amp with tubes in (no input signal - just idle) would I need a cab or could I use the 16 ohm THD hotplate load? Thx
Joseph
Originally posted by The Dude View PostIf you're going to test it without tubes installed, you don't need a load at all.
