Results 1 to 22 of 22
Thread: 49,2 mm P-90 parts source
    Feb 2010
    65
    Hi,
    I'm looking for a source for 49,2 mm P-90 parts source, baseplate, keeper, bobbins.
    I find only 50 mm parts. can someone help, please?
    Senior Member LtKojak's Avatar
    Feb 2008
    Milano, Italy
    971
    Received: 6/3
    Quote Originally Posted by marcfrom View Post
    Hi,
    Being the P-90 born as a 50.8mm, I don't think you'll have any luck finding alternative measures.
    It's actually not that difficult to make your own bobbins. Keeper bars of that measure are found everywhere. You only need to adapt the baseplates, which is more than feasible if you have some power tools and the right bits.
    If you expected to find everything ready to assemble, then, making a Seinfeld reference, "No soup for you!"
    HTH,
    Pepe aka Lt. Kojak
    Milano, Italy
    Feb 2010
    65
    Thanks for your answer LtKojak,
    Actually, I want to propose a butyrate covers, but I only find it in 49,2 mm.
    Maybe the best way should be to find a 50 mm butyrate covers. Do you know if it exist ?
    Feb 2008
    Milano, Italy
    971
    Received: 6/3
    Sorry, why butyrate?
    Pepe aka Lt. Kojak
    Milano, Italy
    Feb 2010
    65
    Because my client ask this. The ivory color is also different than ABS.
    Butyrate 50's P90 Pickup Cover 1 15/16" (49.2mm) - Vintage Cream - Philadelphia Luthier Tools & Supplies, LLC
    Feb 2015
    122
    Received: 21/0
    49.2 will possibly work with 50 mm parts- were talking the two outside poles would be off set by .38mm and the inner poles would be less so unless your pole piece screw heads are maximum diameter youll probably never notice.
    Feb 2010
    65
    Hi Jason,
    I already tried my 50 mm P-90 with the 49,2 Gibson ABS covers but it does not fit in.
    I don't understand why the pickup parts manufacturers build all parts, bobbins, baseplate in 50 mm only and the butyrate covers only in 49,8 mm.
    Does someone have an idea ?
    Old Timer
    Feb 2010
    Just south of Bawlmer, Merlin
    2,381
    Received: 95/1
    Given: 67/1
    Why can't you find a pack of hotdogs and a pack of hotdog buns with the same number in each pack?
    Why do manufacturers make metrically-dimensioned parts for U.S. designed pickups which were originally dimensioned in inches?
    Why do I have to search out pots with 6.35 mm (=.25") diameter shafts, or use 6mm shafts with some kind of bushing or spacer, so that my Fender knobs will fit without wobbling?
    -rb
    Feb 2010
    65
    It's not comparable,
    There's no problem to find a 6.35 mm pots and 6.35 mm knobs.
    I mean there should be a request for a butyrate covers in 50 mm, because it's the only measurement we can find for P-90 parts.
    I'm sure you can find a hotdog buns with the same lenght of hotdogs too.
    Old Timer
    Feb 2010
    2,381
    Received: 95/1
    Given: 67/1
    No, as LtKojack has alluded, both the parts and the covers should be 50.8 mm.
    Because the original measurement was 2".
    And if wishes were horses, then beggars would ride.
    -rb
    Feb 2008
    Milano, Italy
    971
    Received: 6/3
    P-90 Plastic Pickup Bobbin 50mm
    Looks like Mojotone's site "PickupParts" menu isn't working... anyway, they have everything you need with the metric 50mm polepiece spread. P-90 Nickelsilver baseplates, keeper bars, bobbins and plastic covers.
    HTH,
    Pepe aka Lt. Kojak
    Milano, Italy
  12. #12
    Feb 2010
    65
    Quote Originally Posted by rjb View Post
    -rb
    You are a philosopher
  13. #13
    Old Timer
    Feb 2010
    2,381
    Received: 95/1
    Given: 67/1
    Another MEF member once called me "charming".
    I don't think he meant it either.
    -rb
  14. #14
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    5,231
    Received: 319/0
    Given: 255/0
    Could be your proximity to "Charm City," sweetie...
  15. #15
    Old Timer
    Feb 2010
    2,381
    Received: 95/1
    Given: 67/1
    That's "hon" to you,... sweetie.
    "Charm City" was a passing fancy. We're back to "Mobtown" now.
    -rb
  16. #16
    796
    Received: 2/0
    Quote Originally Posted by Lollar Jason View Post
    In my experience, 49.2 and 50 mm parts can be made to work together with very little difficulty 99% of the time.
    The only exception I've found to this was a customer who recently had me make a bucker for his Parker Fly and I made the mistake of going 50mm instead of 49.2. The pickup is leg-less and mounts to the guitar via the two outer (high E/low E) pole screws and the Parkers are 49.2. In this case 49.2 and 50 didn't get along at all. But otherwise, yes, even with metal humbucker covers, they will work together.
  17. #17
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,081
    Received: 18/0
    Given: 13/0
    So all you want is the bobbin ? ,Contact Jon Gundry from Throbak he makes 49.2 mm period correct 50's style p-90 bobbins .
  18. #18
    Feb 2010
    65
    I', not sure Jon will sale only the bobbins.
    Actually I ordered a 49,2 mm butyrate covers and will try it with my 50 mm soap bar as Jason said.
  19. #19
    Sep 2011
    Minneapolis
    284
    Quote Originally Posted by copperheadroads View Post
    And open that wallet wide.
  20. #20
    Senior Member jack briggs's Avatar
    Oct 2007
    Raleigh
    262
    Received: 1/0
    Given: 5/0
    -rb
    I have 2 vintage Gibson P90s - one from 1953. They both measure 1.9375" pole to pole, or 49.2mm. When are you suggesting that they were 2"?
    cheers,
  21. #21
    Oct 2007
    Raleigh
    262
    Received: 1/0
    Given: 5/0
    https://www.throbak.com/repair-parts--screws.html
    cheers,
  22. #22
    Old Timer
    Feb 2010
    2,381
    Received: 95/1
    Given: 67/1
    Quote Originally Posted by jack briggs View Post
    Oops. Looks like you caught me talking out my arse.
    I took LtK's word when he said:
    Quote Originally Posted by LtKojak View Post
    Since 50.8mm happens to be exactly 2 inches, I naturally assumed....
    But, errm, couldn't those bobbins have shrunk a bit in 64 years?
    -rb
  1. P-90 bobbins with 51 - 53 mm spread
    By GunbarrelCustom in forum Beginner/ Hobbyist
    Last Post: 04-21-2014, 06:14 AM
  2. Source for 49.2mm P-90 Soapbar Covers?
    By PoorMan in forum Pickup Makers
    Last Post: 07-23-2012, 06:29 AM
  3. Replies: 0
    Last Post: 04-30-2012, 05:54 AM
  4. Source for a PT for a Marshall 9005 Power Amp (other than MM)?
    By wizard333 in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-05-2010, 04:14 AM
  5. 53 mm and 50 mm Cream Bobbin color ??
    By Electricdaveyboy in forum Pickup Makers
    Last Post: 12-21-2008, 11:50 PM
