Results 1 to 5 of 5
Thread: Transistor substitution
    Senior Member Guitarist's Avatar
    Jul 2006
    506
    I'm building a HoneyBee Overdrive and do not have a 2N5952 (2N5457). I do have many 2n7000 (SHO) and 2N3904 (wah upgrade). I enjoy the sound of 2n7000 mosfets and would actually love to plug these in where I can.
    I suppose we deal with these sub types often. Is there an app that helps with this inc. pinouts?!
    Here's a list from Guitarnuts:
    NPN bipolar transistors
    2N5088
    2N5089
    2N3904
    2N2222
    2N5013
    BC108/109
    PN2369A
    MPSA18
    MPSA13 (this is a darlington - 2 transistors strapped together - but it is interchangeable with the other transistors if you want much higher gain)
    PNP bipolar tranistors
    2N3906
    2N5087
    N-Channel Jfets
    J201
    2N5457
    2N5458
    MPF102
    N-Channel Mosfets
    2N7000
    BS170
Name:	7000 mosfet pinout - Gate and drain tied together.png
ID:	43867   Click image for larger version.
Name:	sho pedal Mad Prpf.jpg
    May 2010
    Sioux Falls, SD
    5,309
    Received: 256/0
    Given: 219/0
    Just Google for the datasheets and compare.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,291
    Received: 354/5
    Given: 356/5
    Please post the schematic of the pedal you are actually building.
    The HoneyBee I found uses 2 x BF244 Fets; can be roughly substituted by other plain Fets, such as those you mention about, but NOT 2N7000/BS170 which are enhancement Mosfets.
    Opposite biasing needs so you can not plug one instead of the other.
    Neither can you use bipolars there, try to get proper, junction type NCH FETs.
    Jul 2006
    506
    Ok that helps clarify. Thanks so much, I REALLY like this circuit's tone!
    Attached Files Attached Files
    Supporting Member
    Dec 2009
    UK
    3,253
    Received: 20/0
    Given: 2/0
    For transistor substitution I use alltransistors.com.
    For small-signal use almost any transistor will work so long as the gain is roughly similar. Many years ago Elector magazine abandoned specifying bipolar transistors other than for highly selective applications. The simply labelled them on the schematics as TUP (Transistor Universal PNP) and TUN (Transistor Universal NPN). I also take the same approach with FETs and don't chase down specific parts unless there's a really good reason to.
  1. kustom k100-0 pc103 driver transistor substitution help.... HELP
    By supawah in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-23-2013, 07:04 AM
  2. What substitution can I use for this transistor?
    By 1WoodHippie in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-03-2012, 08:40 PM
  3. Help with a tube substitution
    By flythair1 in forum Tubes (Valves)
    Last Post: 06-07-2009, 05:15 AM
  4. Peavey output transistor substitution?
    By Neal in forum Music Electronics
    Last Post: 11-22-2006, 01:54 AM
  5. Capacitor Substitution
    By Direwolf in forum Build Your Amp
    Last Post: 11-08-2006, 10:51 PM
