I know there's one out there somewhere as I've seen snippets posted on the web. What I'm after is a factory-issue schematic. All I can locate is a redrawn version intended to construct a pedal, but the component references and ICs don't represent the actual unit.
Mesa V-Twin pedal schematic request
Maybe this?Attached FilesEducation is what you're left with after you have forgotten what you have learned.
Thanks, Enzo - that's the one I already have. The one I'm working on doesn't use single op-amps and the switching/muting is different to the schematic. I can figure it out, but the schematic would be easier. I'll try Mesa to see if they have something. They're usually pretty good, but I always end up needing info on a Friday night for a job that's required the same weekend.
