Results 1 to 30 of 30
Thread: Roctron Silver Dragon Stopped Working ?
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    Hi folks,
    Trying to troubleshoot this Roctron Silver Dragon. The owner says it just stopped working after he tightened one of the case screws that supposedly had a ground wire attached to it. He had it in pieces when he gave it to me ,and there is a black wire that looks like it broke off of something , but I can't see where. Maybe it WAS connected to the case.
    I can only find a schematic ,and not much else available on these. He didn't have the proper power supply as he was using a laptop 12v supply.
    I rigged a PS ,and powered it up grounding the black to the case. Switch still doesn't work. The Slayer side just seems to play though with the switch in either position ,and the Awake side plays through on one position ,and no sound when LED is lit.
    There is another LED used in the circuit (LED3) that I tested with the diode function of my meter ,and it was lighting ,then it stopped. Can a regular diode be used to replace this ?
    Thanks all !
ID:	43979   Click image for larger version.
ID:	43980   Click image for larger version.
    Attached Files Attached Files
    Supporting Member
    Texas
    297
    Quote Originally Posted by gtrplayr1976 View Post
    Thanks all !
    According to the schematic, the power supply requires 12VAC; not 12vdc. Most laptop power supplies are 12vdc. What is your power supply providing... AC or DC?
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    Quote Originally Posted by cjlectronics View Post
    Well....I feel like an idiot. lol...Can't believe I missed that. I assumed it was like other switches that use dc. Thank you !
    Supporting Member
    Texas
    297
    I only know to ask this because I have done the same thing... don't feel bad. We are human and easily overlook the simple things. Hopefully, that'll fix it.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,628
    Received: 546/1
    Always check the power adaptor for type as well as for function. I always tell the customer to bring along his power adaptor, that way I know whether his trouble has anything to do with the adaptor. We may find when he put his unit back together he just plugged the wrong adaptor into it. But at least now you can determine if there are any other issues.
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    Had a guy bring me a Casio keyboard.
    Will not power up.
    Where is the power pack?
    Oh, I did not think you needed that.
    Guess what was bad?
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    I absolutely should have noticed it on the schematic. Just overlooked it. The owner doesn't have the original power supply ,and someone told him he could use a laptop PS ,which I'm guessing he tried. All I really have to use is a variac.
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    Quote Originally Posted by Jazz P Bass View Post
    Will not power up.
    Guess what was bad?
    LOL....uh. This guy doesn't have the PS. Someone told him to use a 12v laptop PS.
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    LOL..not the first time I've missed something simple. Have to hook up the variac. It's the only thing I have that puts out AC.
    May 2010
    Sioux Falls, SD
    5,306
    Received: 255/0
    Given: 218/0
    Just had that conversation with a customer last month. I got in a Korg keyboard blown to smithereens. The customer didn't bring in the power supply so I called to ask if he was using the right one or could bring it in. He said, "Well, it fits in the jack, so it must be the right one". It wasn't.
    Old Timer
    Chill-Ville, VA
    2,589
    Received: 131/1
    Given: 269/6
    Hahahahahaha! Like the time I swapped the 6V6 & 5Y3 in my Champ...
    Justin
  12. #12
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    LOL...of course
  13. #13
    May 2010
    Sioux Falls, SD
    5,306
    Received: 255/0
    Given: 218/0
    Quote Originally Posted by Justin Thomas View Post
    Justin
    So, you had to rewire the sockets to make it work?
  14. #14
    Old Timer
    Chill-Ville, VA
    2,589
    Received: 131/1
    Given: 269/6
    I'll just say I was really happy to have that 11-second warmup time...
    My buddy who didn't realise his 100W Peavey's 6L6s had busted base guide pins wasn't so lucky... he pulls the tubes, puts them back in, and I get a phone call: "hey, I turned my amp on & the tubes lit up like a 100W light bulb?"
    One of my favorite things about working with tubes is the abuse and ignorance they'll survive...
    Justin
  15. #15
    30,628
    Received: 546/1
    On the other hand, output transistors are rarely plucked from their sockets and put back in backwards.
  16. #16
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    Connected this FS to my variac set at 13V ,and she works , but hums badly. Could be this black wire that was broken ,and I have no idea where it broke from. Looks like a ground , but grounding to the chassis makes no difference. It's connected to one side of LED3 that shows to ground. Any ideas ?
  17. #17
    Feb 2010
    10,185
    Received: 330/1
    Given: 645/0
    Is Led3 working without that wire connected? It looks to be the 'power on' led.
    Prime suspects for hum would be components that could have been damaged from the use of the wrong supply, like caps or diodes in the supply area.
  18. #18
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    I just checked ,and the LED does work without the wire connected.
  19. #19
    Feb 2010
    10,185
    Received: 330/1
    Given: 645/0
    So then that black wire was used to ground something using the same ground the LED3 is attached to.
    Pretty tough to figure out without a very careful visual inspection, unless someone has posted gut shots on the net.
    Can you post some pics of the guts?
  20. #20
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    I have searched up ,and down for gut shots. I have a few at the beginning of the thread.
  21. #21
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    Just noticed something off with the schematic. R38 is missing. Not sure if it was a change, or someone broke it off.
  22. #22
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    Well that seems to have been a change. I also see other strange changes like resistors in places where caps would be according to the board ,and schematic. This is a strange animal.
  23. #23
    30,628
    Received: 546/1
    "Missing" parts are common in gear, they are just changes. If you ever look at the drawings for some product where you have all ten revisions, you usually find just such changes.
    Frankly, the hum could be from using the variac. For reasons discussed in the widowmaker thread, you might have the neutral side as your hot.
  24. #24
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    Yes sir. That's what I figured after I started looking at the board ,and the schematic.
    I'm pretty certain I have the neutral ,and hot correct. I'm using a polarized plug ,and the end of an old adapter. Would be nice to have the actual power supply.
  25. #25
    30,628
    Received: 546/1
    Simple test: Set up the unit as you described. Don't connect it to an amp, just the power connection. Now measure for AC voltage between the chassis of the unit and earth ground somewhere, like the center screw of a wall outlet. If you see a few volts, you have the variac backwards.
    You can find a 12vAC adaptor at Radio Shack or places like Best Buy.
    In my shop I had a collection of power adaptors, so I could always have a proper supply for anything. I always tell people to bring their supplies with them, but so many do not.
  26. #26
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    I will give that a try. Thanks Enzo !
  27. #27
    Feb 2010
    10,185
    Received: 330/1
    Given: 645/0
    The black wire that is disconnected, is it the one in your pic that goes to the tube board bracket?
    If so, it looks like on the schematic it goes to a ground at the AC adapter jack.
    The green/yel wire lug should go to a chassis screw to ground the chassis.
  28. #28
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    Yes, that's the wire. It isn't long enough to go to the AC adapter jack unless it's connected to a pad on the board that goes to the jack. The yellow/green has a ring on it that goes to one of the foot switches ,and is the chassis ground.
  29. #29
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    I could only see about half a volt.
  30. #30
    Supporting Member
    May 2010
    WV
    879
    Given: 3/0
    If you look at the pictures above , the blue wire is the tube ground. This black one has me baffled. No gut shots of others anywhere to be found.
  1. Rocktron Silver Dragon- tried mods and Q.
    By Guitarist in forum Guitar Effects
    Last Post: 08-06-2016, 05:44 AM
  2. Rotovibe Stopped Working
    By indelirium in forum Guitar Effects
    Last Post: 01-20-2011, 05:34 AM
  3. My Palomino V16 stopped working
    By tonedeciple in forum Maintenance, Troubleshooting & Repair
    Last Post: 09-08-2010, 07:08 AM
  4. AVT150H Head Stopped working
    By ColinBecker in forum Guitar Amps
    Last Post: 03-13-2010, 01:01 AM
  5. Ampeg B2 - Stopped working.
    By frankthompson@37qs.freeserve in forum Other Amps
    Last Post: 10-18-2006, 12:33 PM
