Results 1 to 9 of 9
Thread: Free Way Ultra Switch - Help needed!!!
    Junior Member
    Mar 2017
    16
    Hi everyone,
    I've embarked on a project recently to have a 2 single coil and 2 pot (volume and tone) wired through this Free Way Ultra Switch.
    Well, looks like I bit more than I can chew and I can't understand the switch and how to connect everything up so... I need some help on this.
    This is how I'd like to have the switch wired up:
    Position 1: Neck
    Position 2: Series in Phase
    Position 3: Bridge
    Position 4: Parallel
    Position 5: Off
    Position 6: Series out of Phase
    Would anyone be able to draw me a quick diagram on how I can achieve this?
    Thanks in advance.
    Senior Member bnwitt's Avatar
    Nov 2008
    Southern California
    460
    Received: 1/0
    Have you seen the PDF file of diagrams at the link below:
    http://www.stewmac.com/freeinfo/i-00...radiagrams.pdf
    Barry
    Warning! Some Electronics devices contain lethal voltages that can kill you. If you do not feel qualified to work with dangerous voltages, refer your repairs to a qualified technician. By giving you online advice, I am assuming no liability for any injury or damages you might incur through your own actions.
    Junior Member
    Mar 2017
    16
    Quote Originally Posted by bnwitt View Post
    Barry
    Hi Barry,
    I've gone through all the schematics I got from www.freewayswitch.com but unfortunately none of them is for a 2 single coil 2 pot connection with the functions I'm hoping to get. Sure, for the right person, I'm sure the info is there if you have the knowledge but my knowledge of electronics is extremely limited.
    Thanks for your input.
    Jack
    Nov 2008
    Southern California
    460
    Received: 1/0
    Jack,
    Have you tried sending them an email?
    Old Timer tedmich's Avatar
    Apr 2008
    Sonoma CA
    3,177
    Received: 46/0
    Given: 38/2
    28 terminals and a 6-way switch! $50! Too much for me!
    Its reportedly built in England so at least there's only a minor language barrier... definitely email them, they owe you.
    IMHO if you make a DIY product with a couple hundred permutations you should fully document all of them...
    Junior Member
    Mar 2017
    16
    Well, just an update... I did email them and got a swift reply saying that he'd be willing to get me a diagram for the connections I needed so... That was good advise Barry!
    tedmich, to be fair, they do have loads of different diagrams available on their website... just not what this electronically challenged guitarist needed hahah.
    Thanks both for your inputs.
    Jack
    4,503
    Received: 116/0
    Given: 77/0
    Have you looked into a generic 4 pole 6 position rotary switch? If you can find one that fits your guitar you could get most of the linkages you want. For out of phase linkages I'd suggest using a DPDT p-p pot for one of the volume and tone controls.
    You might also look into the 5 way PRS style rotary switch.
    Steve A.
    P.S. Before soldering up custom wiring harnesses I suggest that you first use test clips to audition the various linkages to make sure that you find them usable.
    Junior Member
    Mar 2017
    16
    Quote Originally Posted by Steve A. View Post
    Steve A.
    Thanks for the input Steve... Good call on those test clips.
    I'm sorted with a diagram now thanks to the guys at Free Way Switch... specially Alasdair. Can only say good things about their personalised service... Fantastic.
    Cheers
    Jack
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,297
    Received: 199/21
    Given: 197/9
    For what you need?
    Looks like a standard 3 way toggle switch, and a push-pull reverse polarity switch would be a simpler approach.
    Possibly use the more expensive 6 way toggle for a two humbucker project.
    GL,
    T
    “When you find yourself in a hole, quit digging.” WILL ROGERS
    Keep Rockin! B_T
  1. Help with 5 way super switch needed Please..
    By vmazz in forum Guitar Tech
    Last Post: 03-04-2015, 12:24 AM
  2. Peavey Ultra plus quiet on crunch and ultra channels
    By btsdvb in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-10-2013, 10:23 PM
  3. Peavey Ultra 120 (tube amp) Schematic Needed
    By AtomicMassUnit in forum Schematic Requests
    Last Post: 07-27-2013, 12:12 AM
  4. Ampeg V4-B ultra lo switch
    By yunger in forum Repair and Restoration
    Last Post: 04-08-2010, 09:07 PM
  5. V-4B Ultra Lo switch
    By Dave M in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-07-2006, 01:12 AM
