Results 1 to 6 of 6
Thread: Ground loops in a guitar ?
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,077
    Received: 18/0
    Given: 10/0
    I know it exist in Amp building but in a guitar ? I'm not convinced & i keep hearing this from newbies .........or players with more basic understanding .
    go ahead let me know what you think ...................
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,628
    Received: 546/1
    I would think only when people mis-use the term ground loop. Many people call anything making hum a "ground loop". To me, a ground loop occurs when two pieces of equipment have differing ground potentials are connected together by an additional ground path, like a cord between two amps. I am not sure how you could have multiple current paths in the ground inside my guitar.
    But I freely admit I am not a guitar guy, I am an amp guy.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,427
    Received: 407/0
    Given: 448/0
    +1
    The differential voltages and relatively short ground leads in a guitar (even relative to their low output and that they will be extremely amplified) seem too low to be problematic. I've never had a particular guitar that seemed to hum more than usual unless it was a gain issue more related to hot pickups. I do know I've read about it happening though. Since I don't have those suspect guitars on my bench I can't verify one way or the other. But I lean toward "Not a problem".
    "A shot gun delivers a force that exceeds the operational range of most systems, such as pumpkins." Antigua
    Old Timer
    Feb 2010
    Just south of Bawlmer, Merlin
    2,379
    Received: 94/1
    Given: 62/1
    If you run the ground wires in a path that forms a closed loop, I suppose you technically have a loop antenna - which is not the same thing as a ground loop as Enzo elucidated. But I doubt it will make any difference.
    Just don't ground your guitar like this:
    Mar 2008
    453
    Received: 2/0
    The ground loops by itself is not a big deal (I saw a lot of working circuits with mistakes) the problem is difference of potential between path in a loop which determine a current to run modulating the signal. Good practice should avoid it.
    Supporting Member
    Dec 2009
    UK
    3,253
    Received: 20/0
    Given: 2/0
    I work on guitar electronics pretty much every day, day-in, day-out. I've never seen a guitar that's had a 'ground loop' (in the conventional sense of the term). If this were possible, then guitars would need to be bus connected, or star-grounded. Sure, there are numerous ground issues that can occur, but the potentials, current flow and resistances involved make the scenario theoretical and based on micro-potentials which would make no audible difference.
    I say that fully with the knowledge that I have a customer who swears he can hear the difference between pickup selections on a Les Paul when the guitar is played acoustically and not plugged in. So, I guess 'hearing' ground loops for some is eminently possible, as are voices from the spirit world.
  1. Ground Loops in AB763 Deluxe
    By mikepukmel in forum Build Your Amp
    Last Post: 03-24-2017, 09:07 PM
  2. Pedalboard Ground Loops
    By mhuss in forum Guitar Effects
    Last Post: 06-22-2015, 04:10 PM
  3. Ground Loops In PC Board Interconnects
    By TomCarlos in forum Guitar Amps
    Last Post: 02-23-2014, 06:14 AM
  4. Hums, ground loops, and strange squeals.
    By theWicked in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-04-2010, 01:59 AM
  5. Lifting Ground Loops in a 6G15 Stand Alone Reverb
    By tubeswell in forum Tweed Builders
    Last Post: 12-03-2008, 02:06 AM
