Bass Varitone
  • Bass Varitone
    Hello!
    I need some help creating a bass varitone like the one of http://www.has-sound.com/
    Could you please give a schematic?
    Or give me some help?
    Thanks!
    Here's a modified version of Craig Anderton's Varitone from the Electronics Projects for Musicians book. It's pretty much the same as the Gibson circuit, but the cap values are different, and it may work better for bass the way it is
    The standard Gibson cap values are .001, .003, .01, .03, and .22.
    The Gibson frequencies are:
    Position 1--> no cut
    Position 2--> -5db at 1,950 Hz
    Position 3--> -12db at 1,100 Hz
    Position 4--> -16db at 620 Hz
    Position 5--> -18.5db at 360 Hz
    Position 6--> -21db at 120 Hz
    Anderton's are .01, .02, .05, .1, and .22.
    In either case you may need to increase the values for bass, with the exception of the .22.
    Anderton says to try and double the values. I used his values and it worked great for bass. I replaced the Baritone push button in my EB-2 with a Varitone using the existing choke.
    Gibson lists a 1.5H choke. Anderton uses the primary side of an audio transformer for the choke, Mouser part 42TM-019. It's DC resistance is 600 Ohms. He lists the value as 5 to 6H.
    I've used an audio transformer from Radio Shack in the past.
    These are fairly easy things to make.
      Thanks!
      So because i don't have such experience, could you please help me with the part list?
      I guess i need:
      - 6 way rotary switch
      - Resistor 47K Ohm
      - Caps: .01uf .02uf .05uf 1uf 22uf (these are the ones you suggest for bass?)
      And what is T1?
      Moreover i solder this circuit with the tone pot and the grounding?
      Thank you very much for your patience and help!
        Originally posted by iassael View Post
        Thanks!
        I guess i need:
        - Resistor 47K Ohm
        And what is T1?
        T1 is a transformer which is being used as an inductor or choke. If you can find a 1.5 to 4 Henry choke coil, that will work. Radio shack sells chokes, but I don't know what sizes they have.
        The transformer in question can be bought from Mouser electronics.
        Here's the link: http://www.mouser.com/search/refine.aspx?Ntt=42TM-019
        You can try those values for the caps.. they should work fine. The bigger the value, the lower the frequency. What the Varitone does is to notch out your midrange at the frequency determined by the cap.
        You wire this in series with the output. So wire it between the tone and volume and the output jack, or before the volume. You see the diagram has an input and output. One side of the transformer (pad marked J) gets grounded, as seem by the ground symbol.
