Results 1 to 5 of 5
Thread: Help Id holland made tube ,looks like el84 not sure though
    Junior Member
    Aug 2017
    20
    0
    The tube comes from an unknown maker .i am told it looks like a valco chassis.there is a rectifier tube called an ez81 then 2 output tubes ,and 2 12ax7 preamps .one of the output tubes is missing and I can't get a id off the tube kniw matter if I stick it in the freezer,use the moisture from my mouth all over the tube and looked at it in different light sources etc....The output transformer is an 8 ohm. All the other tubes say made in holland ,and the amp has a red inked stamp saying September 22 1964.Any kind of help in identifying the tubes or the make will be greatly appreciated .thanks all
ID:	44317   Click image for larger version.
ID:	44318   Click image for larger version.
ID:	44319   Click image for larger version.
ID:	44320   Click image for larger version.
ID:	44321   Click image for larger version.
    Sep 2014
    se texas
    172
    Received: 20/0
    Given: 7/0
    5
    does look like an el84, as to the origin or make of the amp i can't help there, looks well made.
    guessing likely from the 1950s.
    oops guess not from 50s but same style of build.
    Junior Member
    Aug 2017
    20
    0
    Thanks for the reply dstrat .
    Senior Member Pedro Vecino's Avatar
    Jul 2006
    Spain
    584
    Received: 116/0
    Given: 59/0
    13
    Internal structure is identical to EL84 Tungsram (Hungary).
    Junior Member
    Aug 2017
    20
    0
    Thanks very much
  1. Tube ID?
    By Axtman in forum Tubes (Valves)
    Last Post: 07-11-2017, 10:50 PM
  2. What is this tube ID?
    By jan_matejko in forum Tubes (Valves)
    Last Post: 03-11-2013, 09:27 PM
  3. ID this Tube?
    By norby3 in forum Tubes (Valves)
    Last Post: 10-08-2012, 02:51 PM
  4. Tube ID help
    By cryptozoo in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-28-2012, 02:00 AM
  5. Who Made the "Realistic Lifetime" EL84?
    By bob p in forum Tubes (Valves)
    Last Post: 03-07-2007, 03:43 PM
