I picked up a 1965 Gibson GA40T (replaced power transfirmer with one onhand that privides lower B+) with single tone pot ...lacks midrange...bass and treble very clean. Can someone tell me if the circuit design is the reason? If so, can you suggest a component tweak that might ooen up the midranges? Or a total rebuild of the tone stack. Or could the lower B+ be the issue? Thanks.
1965 Gibson GA40T tone control
Are you playing Fender single coils or Gibson humbuckers through it?
For what it is worth I have never heard one of those old Gibsons I thought sounded worth a damn.Education is what you're left with after you have forgotten what you have learned.
Enzo thanks for responding. Been testing it with all sorts ofbguitars. Just has a notch that does not enhance the tone to my ears. I have been finding misc anecdotal bits and pieces online about Gibson tube amps...runs the gamut from killer to crap...there is a lot of variation in the designs. I just dont have thebknowledge to analyze the circuit.
To me it has potential with hand wired chassis to be a great amp once tweaked. Very well built.
I put in an odd speaker that could be part of the complaint, since the original ceramic jensen was crackling, so need to correct that. I found some tone stack info online and will try to jumper in a few tweaks.
We have said it a million times - there is no one thing that will have more affect on your tone than the speaker. It might be as simple as a change there.,Education is what you're left with after you have forgotten what you have learned.
Originally posted by J M Fahey View PostWon´t talk about taste, to each his own, but those bridged T filters definitely cut midrange.
Just disconnect one leg of C4 and C9 and test again.
Someone here suggested interrupting the path of the capacitors to ground with a pot to be able to dial back the effect of the bridged-T filter.
Steve A.
*** I suspect that I was the only person who modded an Epiphone Valve Jr to get a *cleaner* and less powerful sound from the amp...The Blue Guitar
www.blueguitar.org
Some recordings:
Originally posted by Steve A. View PostSomeone here suggested interrupting the path of the capacitors to ground with a pot to be able to dial back the effect of the bridged-T filter.
