If all the grounds just go to the chassis ,then I guess the current would flow in the + side Go through the capacitor and then back out the same + lead .I don't get it .I am thinking that a resistor is soldered inline and I can see the path the current/signal flows.
Does anybody know what is the actual current path on multi cap can
Originally posted by Stevi q View PostIf all the grounds just go to the chassis ,then I guess the current would flow in the + side Go through the capacitor and then back out the same + lead .
The cap may be charging, in which case conventional current flows into the + terminal and exits through the - one into ground, to close the power supply circuit *or* a moment later discharging, current flowing from the + terminal into the load, passing through it, and returning to - terminal through ground.
The cap is never charging and discharging at the same time, or to be more precise, it may be receiving current from supply and sending current to load; but there will always be a net difference between them , said difference will be either positive or negative, occasionally even zero.
I didn't recall seeing the pics earlier. So, I think if you kind of make up a little bundle of your caps and resistors and ground them to the same spot as the original can (or as close as possible) then you should be okay. You may be able to empty out that can and stuff four new and much smaller caps inside the shell, too.
It may not follow OUR "best practices," having g your preamp filter grounded at the same point as your plates and screens, etc. But in practice, bazillions of Champs, Princetons, Gibsons, Ampegs, and others did exactly that, and I think it's safe to assume that they didn't suffer from awful ground loops due to their "wrong" and "inferior" design...
Justin
Edit: for fun, if you get an actual bad Mallory can, take it apart - slowly and carefully. It may help understand how it works. Wear gloves & glasses."Wow it's red! That doesn't look like the standard Marshall red. It's more like hooker lipstick/clown nose/poodle pecker red." - Chuck H. -
Thanks for the info .These capacitors in these cans from what I gather were grounded all together and attached to the can through some aluminum strip that joined to the tabs and the casing and you bend the tabs and solder the tabs and that was your way to ground.Does that sound right?Thanks a bunch
