Results 1 to 8 of 8
Thread: Beam Pentode orientation in relation to mains transformer
    Jan 2014
    Chiraq
    965
    Received: 181/5
    Given: 187/1
    6
    I am confused by a Morgan Jones illustration on pg 10 of this book, Building Valve Amplifiers -- https://drive.google.com/file/d/0B6x...ew?usp=sharing
    I think he means that the proper tube orientation is the tube on the left in the first pic, is that correct?
    Here is another angle
    Edit: 2nd pic is not the orientation I wanted. I have no idea why that image flipped sideways and the other is in normal orientation
    Old Timer
    Chill-Ville, VA
    2,954
    Received: 513/4
    Given: 953/9
    16
    As best I can tell, you have it right.
    Thanks for that - some neat-looking ideas for construction there.
    Justin
    Jan 2014
    Chiraq
    965
    Received: 181/5
    Given: 187/1
    6
    Justin, Im with you. I 90% believe that the left tube is correct orientation.
    Anyone else ??
    I tried to scan to where I thought it might talk about this in the RCA manual but it was page 1024. Not a good page to try for on a PDF format
    Old Timer
    Chill-Ville, VA
    2,954
    Received: 513/4
    Given: 953/9
    16
    I would think the only way to know for sure is to dissect-a-tube & figure out where the BFPs are... Or, what kind of tube is it, and maybe someone has already sacrificed one?
    Or just leave an extra inch on the tube socket wire, and if it makes noise, rotate the socket...
    Justin
    And which RCA manual? Biggest one I have is RC30, 762 pages. Maybe it's downloadable somewhere!
    Senior Member Old Tele man's Avatar
    Oct 2007
    Tucson, AZ
    623
    Received: 52/0
    Given: 3/0
    12
    He's showing the orientation of the electron beams controlled by the beam-forming plates...he's orienting the tubes (and thus the beams) to flow "parallel with" the possible magnetic disturbance field coming from the transformer; ie: plate electron beams in same plane/orientation as transformer core plates (not the windings).
    Jan 2014
    Chiraq
    965
    Received: 181/5
    Given: 187/1
    6
    This picture answers a lot of questions for me.
    Oct 2007
    Tucson, AZ
    623
    Received: 52/0
    Given: 3/0
    12
    Although rather "hard" on the tubes, simply increasing its idle current until it "red plates" will also *show* you exactly where the "beams" are hitting, since where the plate turns red first is where the beams are hitting.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    31,538
    Received: 1,426/7
    54
    Or this similar picture:
  1. Mains transformer as a choke
    By diydidi in forum Maintenance, Troubleshooting & Repair
    Last Post: 12-02-2016, 08:03 PM
  2. Noisy mains transformer
    By Mick Bailey in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-19-2016, 05:35 PM
  3. Replies: 5
    Last Post: 09-05-2013, 03:16 AM
  4. Transformer core orientation
    By SteveJones in forum Build Your Amp
    Last Post: 02-22-2010, 02:10 PM
  5. Help ID a Mains transformer for 135W Twin
    By FFM in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-07-2010, 02:21 PM
