Suggestions for Oscillator to Amp project
  • Suggestions for Oscillator to Amp project
    Good afternoon all,
    I've been humming and hahing for a while now as to whether I should strip out an old valve oscillator and give it a new lease of life as a guitar amp. It's such a well made thing I've been loathe to put it under the knife - as it were - especially as it's still going strong. Trouble is, I have no use for it (my dreams of setting up my own BBC Radiophonics Workshop and becoming the new Delia Derbyshire having been shelved, for now...), so probably better it gets used for something, than gathers dust in a corner of the workshop.
    The question is, what sort of amp to build from it?
    Pertinent info includes, but is not limited to:
    -290VDC B+
    -230VDC B+1
    The heaters are wired for (left to right):
    -1xEF86
    -1xEL84
    -1xECC83
    -2xEL84
    Naturally, the order could be easily changed (the EL84 next to the EF86 will have to go), but it's so neatly wired it seems a shame to change more than I have to.
    It has a U709 rectifier, which I think is equivalent to an EZ81.
    Any suggestions? I'm leaning towards something Vox-like, the EF86 and EL84's being common in early Vox amps. The EF86 has a bad rep for reliability, but I'll not be touring with it - I'm hoping a carefully designed layout should minimise the risks?
    Thanks for looking,
    Matt.
    More photos:
    Also, regarding the transformers, they're sealed units, with no markings. I'll keep the mains transformer, for convenience sake, and since it seems well made (it's a very heavy unit). I'm guessing the second, smaller grey lump is a choke, since there's a voltage drop across it. I doubt the output transformer will be of much use to me, without knowing the specs.
    Aside from that, there are some pretty cool parts. I'm particularly taken with the giant 1524pF cap, at +/- 1%. That's some pretty heavy-duty accuracy!
    Finally, I should mention that the super-sized dial lights up - a feature I'll definitely be keeping
    Matt.
    Edit: It just occurs to me now, I've been thinking for a while of a kind of two-in-one amp, with a low watt, single-ended stage and a higher watt push-pull amp in the same box.
    The current layout of EF86-EL84-ECC83-EL84-EL84 lends itself nicely to a preamp-output/preamp-phase inverter-output topology - in my head at least - with the single EF86 acting as preamp for two seperate output stages.
    Any thoughts?
    I'm thinking it works well on paper, but would present no small number of practical headaches...
      Not familiar with UK test equipment but it could be push pull output.
        My knowledge of UK test equipment is probably less than yours to the power of 10 - notwithstanding the fact that I'm from the UK! Seriously though, everything post choke will be cut and pasted into my parts drawers, barring the turret boards, which I see no reason not to re-use.
        On a practical note - given that I'm something of a beginner - how would I test the output transformer for primary/secondary impedance? Do I need to measure it in situ, or should I remove it from the circuit and test it solo?
          You could measure it in situ. Put 6.3V AC from a filament transformer on the OT secondary and measure the voltage between the EL84 plates. Divide the p-p voltage by the measured 6.3V and square the the result. That gives you the impedance ratio. If the impedance ratio is 1000 then it's perfect for 2 x EL84s driving an 8 ohm speaker. 8 0hms x 1000 = 8k p-p which is the recommended p-p impedance in the EL84 data sheet.
          EF86, ECC83, 2 x EL84 would make a Matchless DC30 EF86 channel.
          EF86, EL84 could be an AC4
            As a beginner you might not be aware that when doing this you can get 100's of volts on the primary. Take care.
              Thanks nick.
                It looks like a perfect fit for a Marshall 18 watt clone. The limiting factor would be the power supply with anything you build it seems to me. Oscillators don't generally have a huge amount of output. Repurposing may draw too much current.
                  Thanks for the advice. I've a quiet week at work so I hope to have time to move on with the project, I'll try what you suggest and see what results I get. Hopefully not a cloud of smoke and a trip to casualty
                  My thoughts exactly. I suppose I'd technically be making a DC15 (or more likely an AC15, since I have the schematic). If I re-purpose the first EL84, I can probably squeeze in some reverb, which would be nice.
                  Matt.
                    Good point, and thanks for the warning. I've been building amps from kits and schematics for a good few years now, and have had enough shocks to remind me to be on my best behaviour when the lid is off.
                    More recently, I've been trying (with limited success) to get my head around the maths behind valve amplifier design, so I describe myself as a beginner in that sense. I'm thinking re-purposing the oscillator as a guitar amp will make a good halfway house between building amps from kits/schematics, and actually sitting down and designing one from scratch, which is my ultimate goal.
                    Probably take me about a decade to reinvent an existing product, but the days are long and there's time to fill...
                    Matt.
                      That would be an excellent choice, if I didn't already have one! Thanks for the advice on the transformer, I hadn't considered the possibility I'd be drawing more current than it had to offer.
                      Without having access to any of the specs, I don't suppose there's any way I can find out how much current it'll safely deliver?
                      Matt.
                        I've come across oscillators with push-pull output. I currently have the output transformer from an HP unit that uses 2x6L6GC outputs. The problem is the (rather beautiful) output transformer is not matched for speaker use. Sometimes high-output oscillators are used for line testing and are matched for 600 Ohm. Some units dispense with the PI and use a small transformer as a phase splitter. Count the wires - 2 means choke, 5 means transformer.
                        The probability is if the oscillator has 2xEL84 and an EZ81 equivalent, then the transformer would provide enough current to drive the output pair. Otherwise there's little point in a manufacturer going to the trouble of installing them.
                        PS, your pics come with the invite for a free F*ck. From the look of the wretched hag in my offering, her milkshakes won't bring all the boys to the yard.
                          Thanks for pointing that out, my adblocker had been shielding me from her 'charms'. Having witnessed the horror, I'll take them down when I get a moment and re-up them as attachments.
                          Aside from that, thanks for the advice. I'll take a closer look tomorrow and see what's what.
                          Matt.
                            I got the love ads too, I thought I had been sleep surfing or something.
                            Mick beat me to it, the output transformer won't likely match up to 4/8/16 ohms, more like his 600. MAybe 150 at the lowest. Also, the power transformer h=may have enough juice for all the heaters, but a pair of EL84s doesn;t mean it has the current capacity to produce 18 watts.
                              A rough and ready estimate can be made by measuring the secondary DCR and the unloaded AC RMS voltage. Assuming 10% regulation, use Ohms law to calculate the secondary current.
                              That is to say, take 10% of your secondary voltage and use V(voltage drop)/R (secondary DCR)= I (secondary current rating).
