Relay
  • Relay
    Trying to replace an obsolete relay--
    its an Omron G5A-234P-DC5
    spec-- http://www.mouser.com/ProductDetail/...C5hgg5QA%3d%3d
    will this work ?
    http://www.mouser.com/Search/Product...3-G5V-2-H1-DC5
    Your replacement should work. It's a higher current relay, but that's better than lower. The only thing I notice is that it's also bigger and the lead spacing is farther apart, which may be a problem if it is PC board mounted.
      thanks duder........its just going on a custom pcb.. i still dont know how to wire my signal in/ out to it. Ive never done a relay circuit i guess... maybe you could check out my other thread ? Just need that answered (lower posts) and i think i can pull this off !!
        Which other thread? Your link is for another relay.
          ahh soory---its in the Mods section....titled Ch switch
            TodayComponents.com - Omron G5A-234P-DC5 Relay
