Results 1 to 3 of 3
Thread: Connectors for 4-wire cables?
    May 2007
    132
    Does anyone have recommodations about connectors for pickups. EMG and Others already use some. Need something to connect pickup to electronics. Connectors between cables are what I'd like. This way I can ship out presoldered "pickguards", and with this option customers are able to easily mount into guitar without pickguards.
    4-wire + ground. So need 5 connections..
    Woodgrinder/Pickupwinder copperheadroads's Avatar
    Jun 2009
    Iceburg Alley ,Newfoundland,CAN
    2,081
    Received: 18/0
    Given: 13/0
    Molex connectors like Gibson use
    Manufacture Part#: 51021-0500
    Manufacture Part#: 50079-8100
    http://www.mouser.com/ProductDetail/...b8Lhd0ObZT6A==
    Pickup Maker David Schwab's Avatar
    Staten Island, NY
    10,946
    Received: 2/0
    Given: 3/0
    I've used the EMG type. You have "pins" which crimp onto the wire, and then a "housing" which houses the pins (The pins are the sockets), and "headers" which are the male plug part on the pickup.
    The Jameco part numbers are:
    Pins part# 100766
    https://www.jameco.com/webapp/wcs/st...gDrillDownView
    Housing, for 5 pins (4 conductors, plus ground)
    163686
    The crimping tool is:
    159266
    Then you need the headers on the pickup end. These are soldered to a circuit board. I used to use a small piece of perf board.
    Headers come in straight, or right angle (like EMG) and are in strips that you cut apart.
    https://www.jameco.com/z/RMH26-Heade...l_2076869.html
    It's not terribly hard to do, but not trivial either. I stopped using the connectors, but I think I'm going to return to using them.
    It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. Albert Einstein
  1. Solder Shrink Sleeve connectors?
    By tedmich in forum Music Electronics
    Last Post: 06-20-2016, 07:16 PM
  2. Locating point of broken wire in cables.
    By diydidi in forum Music Electronics
    Last Post: 04-09-2015, 05:05 PM
  3. 450V DC cables & connectors..?
    By mcgruff in forum Theory & Design
    Last Post: 06-12-2014, 11:28 PM
  4. Replies: 4
    Last Post: 11-13-2013, 02:16 AM
  5. New Gibson Pickup Connectors
    By izzybell2810 in forum Guitar Tech
    Last Post: 06-14-2009, 06:09 PM
