I understand there are two types of safety capacitors. X capacitors go from hot to neutral, across the line while Y capacitors go from line to ground. Why not replace the infamous death cap with a Y safety cap? Thanks.
Why not replace the "death" capacitor with a "Y" Safety capacitor?
Several manufacturers do just that in current designs. Maybe not on a switch, but from line to ground, which is effectively the same thing.
So I don't see it as any problem using one to replace the 'death cap' as you suggest. I think for most people though, it is too much bother, as just removing it altogether often does not introduce any objectionable noise or hum.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
déjà vu oddness!
Replace Death Cap with Safety Cap?
nearly the same post from 8 yrs ago! Good discussion!
what is the smalest value for this cap to be effective ?.Last edited by catalin gramada; 09-05-2017, 03:28 AM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
As with most things in Life, let alone Electronics, its value is a compromise.
Too large, it will tickle ; too small it won´t do much, pick your`poison.
Time tested values are around .047uF for 100-120V mains and no cap to .022 for 220-250V ones.
Personally I use .01uF on 220V mains to have a noticeable effect but no magic bullet.Juan Manuel Fahey
