Results 1 to 13 of 13
Thread: Multimeters -- Recommendations
  1. #1
    Join Date
    May 2006
    Posts
    804
    Thumbs Up/Down
    Received: 2/0
    Given: 0/0
    Rep Power
    14
    Need a line on an affordable reliable multimeter that doesn't croak and have to be replaced every 6 to 9 months. Any ideas?
    0 Not allowed! Not allowed!
  2. #2
    Stray Cap DrGonz78's Avatar
    Join Date
    Oct 2011
    Location
    Scottsdale, AZ
    Posts
    2,052
    Blog Entries
    1
    Thumbs Up/Down
    Received: 272/5
    Given: 187/0
    Rep Power
    10
    What's your price range? What meters do you NOT want to buy again?
  3. #3
    Master Destroyer nosaj's Avatar
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,108
    Thumbs Up/Down
    Received: 1,016/100
    Given: 141/35
    Rep Power
    11
    Quote Originally Posted by DrGonz78 View Post
    Simpson 260, Fluke 110, and an Amprobe digital meter are what I have settled on. Paid about 30 for each.
    nosaj
  4. #4
    Pickup Maker David Schwab's Avatar
    Join Date
    May 2006
    Location
    Staten Island, NY
    Posts
    10,951
    Thumbs Up/Down
    Received: 8/0
    Given: 6/0
    Rep Power
    27
    Why do they croke? I've been using the same $40 RadioShack meter for the past 12 years! I've even dropped it a few times.
    It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. Albert Einstein
  5. #5
    ToneOholic! big_teee's Avatar
    Join Date
    Jun 2010
    Location
    Mid-South USA
    Posts
    11,279
    Thumbs Up/Down
    Received: 798/32
    Given: 788/14
    Rep Power
    22
    On a digital, the test leads is usually what goes south.
    Most meters will last a while.
    I like the many cheap meters available, for what I do.
    No need to use my Fluke 89 to check many functions.
    One feature I like on a meter, is a separate on and off switch.
    I don't care for the ones where you use the main select switch to also turn it on and off.
    A separate on/off, allows leaving the main select switch to be preset, or left alone, but not many meters have this feature.
    I typed in digital multimeter on amazon, and here's the result.
    https://www.amazon.com/s/ref=nb_sb_n...tal+multimeter
    T
    If Wishes Were Horses, Beggers Would Ride! (Carmichael's Proverbs 1628)
    Terry
  6. #6
    Senior Member salvarsan's Avatar
    Join Date
    Jan 2008
    Location
    The pines country.
    Posts
    1,089
    Thumbs Up/Down
    Received: 1/0
    Given: 4/0
    Rep Power
    14
    The price important.
    I put $225 into a 5-digit handheld model B&K was discontinuing in 2002. I still have it.
    That functionality in a handheld costs $200-500 today.
    If you want that last fraction of an ohm when doing a DCR measurement, 5-digit multimeters are also called "50,000 count" and are shown displaying 49,999 or 50,000 in the sales copy.
    Similarly 4-1/2 digit ones are 20,000 counts = 19,999.
    Testequipmentdepot.com is a good place to research this.
    You might consider getting a refurbished benchtop meter if the price is right.
    The lofted fewmet doth soon hew close to the whirling blades.
  7. #7
    Old Timer Leo_Gnardo's Avatar
    Join Date
    Sep 2012
    Location
    Dogpatch-on-Hudson
    Posts
    6,187
    Thumbs Up/Down
    Received: 1,217/15
    Given: 1,110/0
    Rep Power
    13
    Quote Originally Posted by salvarsan View Post
    Gotta put in a word here for my 45 y/o 8000A benchtop Fluke DMM. Just can't kill it, lord knows I've tried.
    Also have a couple $30-40 Shack DMM's both about 25 years old, they keep pluggin' along too.
    No fancy features on any of 'em just ACV, DCV, AC current, DC current, & ohms.
  8. #8
    Old Timer
    Join Date
    Feb 2010
    Location
    Just south of Bawlmer, Merlin
    Posts
    2,656
    Thumbs Up/Down
    Received: 351/6
    Given: 345/1
    Rep Power
    12
    OP has not specified resolution & accuracy needs, or mentioned which mm models have croaked or how or why they croaked.
    My little ~45 y/o analog Radio Shack "Micronta" still works... well enough to test pickup polarities....
    None of my litter of $5.99 (FREE with coupon & any purchase*) 3-1/2 digit Harbor Freight "Cen-Tech"s have croaked yet.
    *There happens to be a FREE offer this weekend (Fri-Sat-Sun).
    https://www.harborfreight.com/
    But don't waste the extra dollar for the $6.99 Cen-Tech with battery-killing superfluous backlight. That one did croak.
    My "expensive" HF meter with impact-resistant housing has been dropped into an engine compartment a few times.
    It hasn't croaked.
    A while ago, I tried to salvage an old Simpson that had spent decades in a soggy basement full of shelves of various chemicals.
    But that meter was pretty croaked.
    -rb
  9. #9
    Supporting Member
    Join Date
    Dec 2009
    Location
    UK
    Posts
    3,304
    Thumbs Up/Down
    Received: 80/0
    Given: 5/0
    Rep Power
    13
    Some DMMs have difficulty in measuring DC resistance of a pickup, especially in an electrically noisy environment. The induced voltage can be enough to skew the reading. I have a couple of autoranging Fluke meters and the voltage is enough to flip from resistance scale to voltage. With my Wavetek if I switch on my benchtop fluorescent magnifier I can see the DC resistance shift by 200 Ohms or sometimes more.
    I wonder if this is why sometimes customers complain of differences between the advertised resistance and the one they read?
  10. #10
    Join Date
    Jun 2010
    Location
    Mid-South USA
    Posts
    11,279
    Thumbs Up/Down
    Received: 798/32
    Given: 788/14
    Rep Power
    22
    The biggest varible of DCR pickup resistance is the Air Temperature.
    Usually 68-70F degrees will get you close to stock DCR.
    T
    Terry
  11. #11
    Lifetime Member Enzo's Avatar
    Join Date
    May 2006
    Location
    Lansing, Michigan, USA
    Posts
    31,715
    Thumbs Up/Down
    Received: 1,600/7
    Given: 0/0
    Rep Power
    54
    When you try to take resistance readings in an inductive environment, always try setting the autoranging feature to a range hold first. As it hunts during autorange, the current changes, which is enough to kick the coil and the resulting spike confuses the meter, which goes to hunt some more.
  12. #12
    Old Timer
    Join Date
    May 2006
    Location
    Boston, MA area
    Posts
    2,644
    Thumbs Up/Down
    Received: 20/0
    Given: 0/0
    Rep Power
    17
    Quote Originally Posted by Mick Bailey View Post
    I have never observed this effect. The better DMMs choose aperture times that are integral multiples of the duration of one cycle of the local power frequency, 50 Hz or 60 Hz. There are some aperture times that are integral multiples at both frequencies. The reason is that well-chosen aperture times have profound discrimination against power-line interference. The aperture start time need not be synchronous with the power line - only the window duration matters.
    1 Not allowed! Not allowed!
  13. #13
    Join Date
    Jan 2015
    Posts
    37
    Thumbs Up/Down
    Received: 2/0
    Given: 1/0
    Rep Power
    0
    This is the best affordable DDM that I ever seen, I love it.
    I also have a Fluke 179, but to be honest if at the time I bought the Fluke there was the UNIT-T at the market I would not spend money on a Fluke
    Unit-T UT136B
    https://www.ebay.co.uk/itm/UNI-T-UT1...0AAOSwgzFbaA-v
Thread Information
Users Browsing this Thread
  1. Multimeters
    By TOA Bassman in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-28-2017, 06:54 PM
  2. Looking for recommendations
    By mickboom in forum Guitar Amps
    Last Post: 09-16-2010, 06:03 AM
  3. Multimeter recommendations
    By wolf1728 in forum Music Electronics
    Last Post: 04-24-2010, 07:10 PM
  4. Tube Recommendations?
    By Jaicen in forum Tubes (Valves)
    Last Post: 01-27-2009, 10:58 PM
  5. Multimeters
    By MarkL8 in forum 5 E 3
    Last Post: 03-30-2007, 05:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
