Results 1 to 9 of 9
Thread: ripple question
    Mar 2008
    453
    Received: 2/0
    ripple question
    Hello, can someone explain what means the ripple modulation in my second pic,please? That meant ripple voltage over first anode filter cap, looks like sort of modulation when draw a certain amount of current. Thanks.
    iddle
    400mA
    sorry for pic quality
    This pics was done at 400cps . Of course it looks worse at low freq. and very smooth going up. It is a sign for bad cap ? Looks like it not decouple enough at low freq.? should be worried about, please ? Thanks
    " I know I'm stupid but get courage when look around "
    Old Timer
    Cheshire, UK
    1,831
    Received: 54/0
    Given: 34/0
    Is that with an input signal? It looks like the normal modulation you'd get with a fixed frequency input signal of 400Hz. See LTSpice sim below.
Name:	100Hz ripple + 400Hz.png
    Mar 2008
    453
    Received: 2/0
    Hi. Yes 400hz input signal was applied. The "modulation" start to be visible from 300mA up. I just wonder if is a sign for a bad cap or not enough decoupling capacitance...? or it just looks fine enough ..? Thanks
    Old Timer
    Cheshire, UK
    1,831
    Received: 54/0
    Given: 34/0
    It looks OK to me. The sim was with a 'perfect' cap.
    Near Dallas Texas
    3,400
    Received: 48/0
    Given: 32/1
    The lower the frequency that the amp is outputting, the bigger the modulation you see on B+. More capacitance will reduce the modulation, but also interacts with how bass notes sound and feel. A bass amp needs more capacitance than a guitar amp or it will sound too mushy on low notes. It's worth experimenting with different caps to see what you like.
    WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personel.
    Mar 2008
    453
    Received: 2/0
    Hi. The cap is large enough to keep topped up the voltage even at max power but I.ll keep that, to try to suprime as much considering how it works in tone effect. Thanks
    Supporting Member tubeswell's Avatar
    Feb 2007
    Wellington NZ
    4,136
    Blog Entries
    1
    Received: 47/0
    Given: 14/0
    Quote Originally Posted by loudthud View Post
    +1.
    A decent amount of capacitance on the smoothing cap supply node in Pii filters where the smoothing cap directly feeds the screen supply, will help prevent screen current feedback of LF even order harmonics when the amp is dimed. Getting the rolloff under 10Hz is beneficial, getting under 5Hz is awesome. This is why some amps have higher value smoothing caps.
    Senior Member Old Tele man's Avatar
    Oct 2007
    Tucson, AZ
    584
    Received: 15/0
    Given: 1/0
    Yep, see these old (02-23-2009) postings on this subject: Using large value screen resistors w/ bypass caps
    Oct 2015
    153
    Received: 1/0
    what kind of amp?
    look at one of the output tube plates of a push pull amp at the onset of clipping and you will see the waveform dance all over the place at 120 Hz. this gets cancelled in the OPT so you do not need a huge filter to swamp this out.
  1. ripple rejection
    By uneumann in forum Theory & Design
    Last Post: 08-31-2017, 10:14 PM
  2. Replies: 26
    Last Post: 01-25-2014, 03:38 PM
  3. How much ripple is too much?
    By AMPREPAIR in forum Guitar Amps
    Last Post: 11-15-2012, 03:59 PM
  4. B+ Ripple
    By loudthud in forum Theory & Design
    Last Post: 04-10-2012, 07:50 AM
  5. Ripple rejection???
    By Chuck H in forum Theory & Design
    Last Post: 08-29-2011, 05:49 AM
