Mojotone 5f6a discrepancies......
  • Mojotone 5f6a discrepancies......
    Their schematic looks different than Leo's
    Specifically the location of the choke and I only see 1 rectifier tube. What's gives?
    Technology & costs = current product(s).
      There's only one rectifier tube in all of Leo's Bassman schematics except for the 5E6 & 5E6A.
      As for the choke, Mojo's design looks a little more like what I'm used to, but I don't see where it'd blow anything up if you changed it. Leo's design looks to me a little odd, like is it a choke input or capacitor input, it seems to be both at the same time?
      And Leo & Co. are not immune from mistakes.
      Justin
        This is a standard arrangement for when choke does not feed OT (plates), just everything after.
        The only purely choke input are where you have a much bigger choke that feeds everything.
        (you knew this )
          Indeed to all above... It's actually impossible to identify "discrepancies" without specific schematics. How many Bassmans were there? Which one is the Mojo supposed to be? etc.
            Well, they <DO> specifically call it a "Tweed Bassman 5F6-A Kit," I would think that narrows it down a bit...
            I also noticed some cap values are different. But I would expect that. I'm sure they <COULD> be more accurate, but paying an extra $300 for "proper value" electrolytic caps that were -20/+80% anyway...
            Justin
              The model names are mostly a marketing tool.
              I used to go to a local eatery every day for lunch. They had a "hamburger special" called the works-burger. Hamburger with all the tomato and stuff, french fries, side salad, and a basic dessert. I'd order the burger works, but sub a baked potato for the fries (made it seem more like a real meal), I subbed cole slaw for the salad as my preference. Instead of chocolate cake, they were happy to sub a cup of soup. I really liked their navy bean soup.
              I often wondered if I could get away with then subbing a chicken patty for the beef burger. And philosophically wondered when it ceases to be a works burger.
              So how many detail changes can one make to a 5F6A before it ceases to be one? Cap tolerance? Power cord? Rectifier? REsistor values? Bypass cap values? Power tube type?
                It's nice to provide links
                http://www.mojotone.com/Amp%20Kit%20...tion=overwrite
                http://schems.com/schematicheaven.ne...5f6a_schem.pdf
                Other than the use of modern standard part values, eg 22uF rather than 20uF, I can't see any difference? And as noted, in previous decades ecaps values tended to a rather slack tolerance to their nominal.
                  You remind me of this:
                    Yes, oh yes...
