PPIMV on a jcm800/2204 yes or no ? .. I don't really like it
You REALLY need an attenuator with that amp. Removing the power amp from the clipping reduces the voltage shift dynamic and that can make the amp sound/feel blatty and flat. PI clipping is an important part of the formula, but it's usually only adding harmonic distortion to clipping power tubes. Some amps make good preamp distortion and others need to clip the power tubes. I honestly can't think of one example where the PI clipping the final waveform was better or even as good. YMMV and sorry for your less than positive experience and efforts. Some guys like it.?. But for you, clearly, take it out and get a good attenuator. Look forward to using up a few more power tubes"Take two placebos, works twice as well." Enzo
When you are trying out the new PPIMV, are you running the regular master at full?
This would be the only fair comparison.
If done this way, you prefer the regular master to the PPIMV ?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
i haven't listened to an 800/2204 with a PPIMV, though I have heard PPIMV mods in old plexis and metal face marshalls that i thought sounded pretty good at townhouse volumes on a half stack of greenbacks. those people were using the "Rich Mod" PPIMV before attenuators became widely popular. those PPIMV amps would have been relying primarily on PI clipping and maybe some mild speaker compression rather than power tube clipping and outright speaker IM distortion. so i guess my two cents is to say that a PPIMV doesn't have to sound bad, but it's only a part of the classic Marshall tone.
which PPIMV mod are you using? I haven't traced your circuit to figure out which one you're using, but there are several. I thought the "Rich Mod" sounded pretty good when I heard it, but that was a long time ago. You might want to consider the different flavors of PPIMV mods before scrapping the idea entirely.
my preference is like Chuck's -- I think the PPIMV mods serve a purpose, but I think attenuators give better results. IMO the clipping PI sound is an essential part of the Marshall tone, but it's only part of the formula. the output tubes really matter. You need them both."Stand back, I'm holding a calculator." - chinrest
Another option is to add a pot in series with the LTPI bias resistor. Mojave amps do this on a few models. This has the effect of lowering the headroom of the LTPI so it clips earlier and it reduces the LTPI output swing too. I think the Mojave amps use a 47k pot.
Here is a sim I did to show the effect of increasing the bias resistor
It looks like the standard JCM800 2204 with the lar/mar PPIMV mod.
http://el34world.com/charts/Schemati...l_50w_2204.pdf
I've built it several times, and I thought it worked great.
With the PPIMV on 10, it should be like it is not there, and regulate with the pre MV.
Mine sounded best with the PPIMV above 5.
I did several other mods, and always changed some cap values to suit my tonal needs.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Originally posted by Zozobra View PostAnother option is to add a pot in series with the LTPI bias resistor. Mojave amps do this on a few models. This has the effect of lowering the headroom of the LTPI so it clips earlier and it reduces the LTPI output swing too. I think the Mojave amps use a 47k pot.
Merlin mentions an adjustable PI bias mod like that in his preamp book."Stand back, I'm holding a calculator." - chinrest
of course we know it'll sound better maxed and/or out of circuit... taking it out of circuit gives you both halves of the marshall tone, while using the PPIMV only gives you the PI half of the tone.
the real question is whether or not distorting the PI without frying your ears with the power tubes throbbing gets you something at lower volumes that you couldn't get otherwise. if the answer to that question is yes, then it adds benefit and is worth keeping.
perfect is the enemy of good."Stand back, I'm holding a calculator." - chinrest
Has anyone ever tried half wave clipping diodes to ground at the top of the Lar-Mar Master Volume? These simulate output tube grid current as you turn down the Master Volume.WARNING! Musical Instrument amplifiers contain lethal voltages and can retain them even when unplugged. Refer service to qualified personnel.
Originally posted by copperheadroads View PostI took it out ,It sounded best with it pretty much maxed & i guess then it was pretty much out of circuit then .Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
