Results 1 to 11 of 11
Thread: TDA2050
  1. #1
    Old Timer
    Join Date
    Jun 2007
    Location
    Pensacola, FL
    Posts
    3,576
    Blog Entries
    1
    Thumbs Up/Down
    Received: 10/0
    Given: 5/0
    Rep Power
    16
    TDA2050
    Got a JC40 in with a blown one. Anyone have a few I could buy?
    0 Not allowed! Not allowed!
  2. #2
    Master Destroyer nosaj's Avatar
    Join Date
    Sep 2011
    Location
    Pace, FL
    Posts
    3,342
    Thumbs Up/Down
    Received: 1,176/102
    Given: 167/36
    Rep Power
    12
    Quote Originally Posted by lowell View Post
    If you need it tomorrow try Mcdowell's Electronics on 9th Avenue. They're off the road a bit by a fire station.
    nosaj
  3. #3
    Old Timer J M Fahey's Avatar
    Join Date
    Oct 2007
    Location
    Buenos Aires, Argentina
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    Out of production and EBay ones are relabelled TDA2030 which is still being made.
    Unless you get one from somebody´s cache or some small town Mom and Pop shop which has a few in dusty shelves or a Tech who bought a few too many, your best bet is an LM1875 which are still being made.
    Not 25/30 W rated like 2050 but honest 20W , I guess JC40 is actually 20+20.
    1 Not allowed! Not allowed!
  4. #4
    Join Date
    Jul 2007
    Posts
    608
    Thumbs Up/Down
    Received: 51/0
    Given: 9/0
    Rep Power
    14
    Output power is defined by supply voltage(s) used in the amp and load resistance.
    For this reason, TDA2050 can be replaced with LM1875 and vice versa.
    The output power will be EXACTLY the same.
    Only two electric parameters should be considered when you need to replace output operational amplifier (IC):
    - The maximum allowable voltage of the IC, which is used as a replacement, should be greater than the supply voltage(s) of the amp.
    - The IC, which is used as a replacement, should have a minimum load resistance no more than the original one.
  5. #5
    Old Timer
    Join Date
    Jun 2007
    Location
    Pensacola, FL
    Posts
    3,576
    Blog Entries
    1
    Thumbs Up/Down
    Received: 10/0
    Given: 5/0
    Rep Power
    16
    Thanks for the help guys and sorry for the late reply! haha
  6. #6
    Join Date
    Jun 2006
    Location
    Norristown state hospital
    Posts
    2,360
    Thumbs Up/Down
    Received: 192/4
    Given: 1/0
    Rep Power
    16
    Yikes, you're right they are obsolete.
    There are people selling 2050's on Ebay that are new as well as used ones.
    Got line 6 Spider 30 that needs one.
    A or 2040 or LM1875 won't put out as much power as the 2050.
  7. #7
    Join Date
    Nov 2018
    Location
    United Kingdom
    Posts
    203
    Thumbs Up/Down
    Received: 53/0
    Given: 179/0
    Rep Power
    2
    I bought lots from ebay and from direct suppliers of components of audio spares, they were all fake :/
  8. #8
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    Quote Originally Posted by drewl View Post
    Yes and no, depends on load.
    which should be expanded to:
    Both stand basically same supply voltage ... BUT ...TDA2050 has higher peak current capability (check the datasheets) so:
    * into 8 ohm load, both will put out exactly the same.
    * into 4 ohm load, LM1875 will struggle, be unreliable, and internal protection will probably be triggered at high power: UGLY distortion.
    So what are your speaker loads?
    Ouch!! just checked, apparently user manual says nothing but Forums comment about "4 ohm speakers"
    Not sure in USA ("I can get another at Craigslist") or about what customer might pay but here in Argentina where such amp is considered "valuable" I´d go the extra mile, use an LM1875 and boost its current capability with 2 TO220 power transistors, think TIP41/42 class (not a typo, not TIP141/142, not darlingtons), mounted on same heatsink if they fit.
    Total parts count: 3 ; 1 transistor pair + one 2 ohm 1W resistor
    If going that way, I´ll draw the safe stable circuit, NOT the one which is all over the place.
  9. #9
    Join Date
    Jun 2006
    Location
    Posts
    2,360
    Thumbs Up/Down
    Received: 192/4
    Given: 1/0
    Rep Power
    16
    Yeah I compared the datasheets and since the load is too much for a 2040, I ordered a 2050, will be here Monday.
    If I find a decent source I'll buy a few as spares.
  10. #10
    Join Date
    Oct 2007
    Location
    Posts
    11,753
    Thumbs Up/Down
    Received: 1,884/23
    Given: 1,463/35
    Rep Power
    27
    Just curious where you ordered it?
    Reliable suppliers are all but dry.
  11. #11
    Join Date
    Jun 2006
    Location
    Posts
    2,360
    Thumbs Up/Down
    Received: 192/4
    Given: 1/0
    Rep Power
    16
    Quote Originally Posted by J M Fahey View Post
    Random re-seller on ebay.
    seems to be several people selling them.
    if it's the real deal I'll stock up on a dozen or so.
Thread Information
Users Browsing this Thread
  1. Vox Cambridge 30 Reverb Twin keeps blowing TDA2050
    By acorkos in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-22-2015, 07:51 AM
  2. Current booster circuit with TDA2050
    By Aleko in forum Build Your Amp
    Last Post: 02-17-2010, 12:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
