Results 1 to 21 of 21
Thread: Fender Champ Power Output Rating
    Jun 2017
    Ontario, Canada
    266
    Received: 14/0
    Given: 18/0
    Hi there, first time posting in this section. My question has to do with power ratings for a single 6V6 amp such as a Fender Champ. I worked on a similar amp recently, a Harmony 8418 made by Valco. I calculated the power dissipation of the power tube to be just over 10 watts, which seemed reasonable since 6V6's are rated for 12 watts max dissipation. What confuses me though is that the literature on the Fender Champs says they are 5 watt amps. Am I missing something here? Why would they design the Champ to output only 5 watts if they had up to 12 watts available from the power tube?
    B.L.
    Jun 2011
    South West Arkansas
    158
    Received: 17/0
    You are confusing tube dissipation with the amp output power..Typically output power will be something less than 60% of the tube dissipation.
    Jun 2017
    Ontario, Canada
    266
    Received: 14/0
    Given: 18/0
    Quote Originally Posted by bobloblaws View Post
    B.L.
    Oh, OK. I thought it was pretty much the same thing. I know how to calculate tube dissapation, is there a way to calculate output power? Or do you have to look at the output waveform on a scope?
    A Deluxe Reverb cranks out 11 W per 6V6. Is the difference because one is class A and the other class AB?
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    5,580
    Received: 662/15
    Given: 712/0
    5 watts - from 400 or 500 Hz on up. You'll be very disappointed at the puny power of the mighty Champ at 100 Hz. Like 1 watt or less, clean sine wave. Of course you can measure some distorted waveform and find a larger power figure but any way you look at it, the power is very limited at lower frequencies.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,947
    Received: 894/5
    Output power is what audio power it can put into a load. A crude method would be to measure the signal voltage across the load (speaker) and use Ohm's Law to calculate power.
    Jun 2017
    Ontario, Canada
    266
    Received: 14/0
    Given: 18/0
    So why is the output power of a Deluxe Reverb, for example, so close to that of the tube dissipation while the Champ is roughly only half? Something to do with efficiency and/or amp class?
    Senior Member Old Tele man's Avatar
    Oct 2007
    Tucson, AZ
    586
    Received: 19/0
    Given: 1/0
    Po ≈ (Zo')*(gm*Vg)^2
    where:
    Po = Output power, watts(avg)
    gm = tube transconductance, A/V
    Vg = grid-signal AC-drive voltage(*)
    Zo' = effective plate load impedance, Ω
    NOTE: (*) with PP circuits: (1) assume the bias voltage is the limit of the AC-drive voltage (ie: Class-AB1) and (2) Zo = Zoo/4 roughly.
    Lest We Forget g1's Avatar
    Feb 2010
    10,431
    Received: 595/21
    Given: 1,322/5
    Yes. Class AB is much more efficient than class A.
    Amplifier Efficiency
    http://www.electronics-tutorials.ws/...r-classes.html
    Dec 2008
    Wernersville, PA
    12,453
    Received: 181/2
    Given: 84/0
    Also, I believe that you are missing the relationship that the output tube has with the output transformer.
    Jun 2017
    Ontario, Canada
    266
    Received: 14/0
    Given: 18/0
    Right, that makes sense to me now, thanks all.
    Jun 2017
    Ontario, Canada
    266
    Received: 14/0
    Given: 18/0
  12. #12
    Jun 2017
    Ontario, Canada
    266
    Received: 14/0
    Given: 18/0
    Quote Originally Posted by Jazz P Bass View Post
    As in "reflected load" etc.? I read up on that awhile back, I would have to refresh my memory.
  13. #13
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,413
    Received: 560/15
    Given: 456/13
    Preferred method, simply because itīs "real World" is to drive amp to just clipping, checking that on a scope screen , and do the Math.
    Now when you are *designing* an amplifier, when there{s nothing to turn on and measure yet, just some drawings and calculations on a piece of paper, the regular method is to calculate it using the tube curves, available from the datasheet. (thatīs what they are there for).
    Here{s an example, not exactly of a Champ, but similar principles apply:
    Details to be considered:
    1) the (incredibly useful) curves , showing:
    Current
    plate voltage
    grid voltage
    dissipation
    etc. , in all combinations.
    personally I like "graphic" design using curves instead of "digital" design using simulators any day of the week, because although the latter can crunch numbers "apparently" very precise (as "0.5384% distortion", "102.257 mA current" ... REALLY????) but graphics show you "all data at once".
    Ok, in the example you have a tube with 300V plate , 100mA plate, both at idle, and designer drew a 4000 ohm load curve.
    See that plate voltage can swing from 0V (nominally, actually some 60/80V minimum "saturation voltage") to twice +V or 600V and current can swing from 0mA to 200 mA (again , nominal, actual tubes might have difficulty reaching that, specially if worn)
    So here you have 300V peak swing, 100mA peak swing, so 300*0.1=30W peak Watts (yes, it{s actually that simple) so 15W RMS possible.
    Now I said that actual peak voltage swing will be less, some 300V minus 80V saturation voltage so 300-80=220V peak or 73% what an "ideal" unobtanium tube would achieve.
    By the same token, current swing will also be 73% of ideal value, so 73 mA peak.
    So letīs recalculate using real world tube values (which are also shown in the datasheet, they are the bent *real* curves) 220V peak * 73mA peak=16W peak , so 8W RMS ... which matches very well with what we can get from a real world "Champ", using an EL34.
    By the same token, you will find the 6V6 one can provide some 50W RMS.
    As you see, amps *can* be designed, and very accurately, just with curves, pencil, paper and calculator
    By the way, whay Leo and others dis, no doubt.
    Not many copmputers available way back then
    Nor calculators, the calculation tool used by Engineers was the mighty slide rule:
    EDIT: now I notice I had only a very quick look at the graph, did all after it in my mind (since I do it *often*) and thought idle current was 100mA.
    Itīs actually 80mA so that value should be used instead, lowering end results a little, but too lazy on a Mothersīs day Sunday afternoon to rewrite everything with corrected values, in any case the procedure is correct, Math is correct .... just does not exactly apply to the graph I pulled from the Net.
    The *method* is the one I showed in any case.
    EDIT2: maybe this will clear OP doubts:
    *idle* power dissipation is 300V * 80mA=24W, yet we only get less than 8W RMS
    terrible but true
  14. #14
    Jun 2017
    Ontario, Canada
    266
    Received: 14/0
    Given: 18/0
    Wow, that is a lot to digest. I come across references to the tube curves quite often but I don't know much about it. I will definitely study this info when time permits.Thanks!
    - B.L.
  15. #15
    Oct 2015
    153
    Received: 1/0
    push pull amps are like making toast, you press the lever down and the toaster starts to heat up, the toast is done and it pops out and the toaster cools off,
    well, a class A amp like the Champ is like having the toaster on all the time, maybe not as hot, but always on, the tube does not like this, it will protest after a while, so we have to limit the plate dissipation of the tube a bit so it does not fail.
    this means we can not get as much juice from the Champ as we do in the Deluxe Reverb.
    In the Deluxe Reverb, the tubes get to cool off every half cycle.
  16. #16
    Jun 2017
    Ontario, Canada
    266
    Received: 14/0
    Given: 18/0
    Quote Originally Posted by cjenrick View Post
    That is an interesting analogy. But in the example I gave, my amp was biased so the 6V6 was dissipating about 10.3 watts which is about 85% of the max 12 watts. That is more than the conventional 70% for push pull amps. Robinette's bias calculator (https://robrobinette.com/Tube_Bias_Calculator.htm) indicates that 90% is safe for cathode bias amps and 100% is safe for class A fixed bias. The general thrust of the other replies appears to be that it is a question of efficiency and not less dissapation that results in the lower output. Or am I confused by your use of the term "plate dissapation".
  17. #17
    Oct 2015
    153
    Received: 1/0
    at 10 watts Class A i am afraid you are going to be buying a lot of tubes,
  18. #18
    Aug 2012
    Great Black Swamp
    1,895
    Received: 145/0
    Given: 386/1
    The latest Champ, the reissue 600, runs with 360vdc on the plate and -22vdc bias, for ~338vdc anode-cathode potential. Schem here: Champion 600
    Using an online tool, I read 15.5W total dissipation. This includes plate and screen; if screen is 20% then plate is ~12.4W and the screen is the other 3.1W. To answer the OP, this 90% continuous plate dissipation has nothing to do with audio output power. The output power using the schem's indicated 7vac is about 5W. Cranking the amp will get significantly more.
    I've been ionized, but I'm okay now. - Buckaroo Banzai
  19. #19
    Jun 2017
    Ontario, Canada
    266
    Received: 14/0
    Given: 18/0
    I get similar (15.9W) with Robinettes calculator.
    ...if screen is 20% then plate is ~12.4W and the screen is the other 3.1W.To answer the OP, this 90% continuous plate dissipation has nothing to do with audio output power.
    I understand now that I had originally confused tube dissipation with audio output power, but what value constitutes 90%, and of what? Max dissipation for that tube is 12W, no?
    I'm not trying to be nit-picky, I just want to understand your points accurately. Did you mean 3.35vac? That is what I see on that schematic at the output, TP13. There is a reference to 7vac at TP5.
    My understanding was that when the output spec is listed at 5W it refers to the max output. Or does it refer to distortion free output?
  20. #20
    Jun 2017
    Ontario, Canada
    266
    Received: 14/0
    Given: 18/0
    The online calculators seem to indicate that 10W plate dissipation is well within the acceptable range for a 6V6. If I'm missing something I'd really like to know what it is.
  21. #21
    Aug 2012
    Great Black Swamp
    1,895
    Received: 145/0
    Given: 386/1
    The number I'm using is 14W, although I have seen ONE source that calls out 12W. Not sure the reason for the discrepancy. Maybe the GT designation indicates 14W?
    Yes, TP5 is where I'm getting the number. In the online calculator I used, 7vac (or about 20vpp) at the grid of the power tube resulted in ~5W output power. I didn't check, but I assume this is about the limit of clean power. Or it 'just happens' to be the voltage at the grid with the design input signal. With the 6V6 slammed, you'll get 7 or 8W of snarling distortion.
    edit: I think it's up to the maker to assign a distortion figure to their rated outputs. For Fender, it's generally a clean signal. For some others, not so much - presumably because the user won't play the amp clean. Why advertise an amp as an 80W amp when it can be advertised as 150W?
  1. Fender Champ XD No Output
    By Pryde in forum Maintenance, Troubleshooting & Repair
    Last Post: 08-30-2015, 06:35 PM
  2. rule of thumb ? speaker power handling rating v.s. amp power output.
    By tonequester in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-10-2012, 01:53 AM
  3. Replies: 7
    Last Post: 01-31-2012, 09:55 AM
  4. Mojotone Fender 5F1 Champ No Output Debugging Help?
    By LastLS1 in forum Debugging Your Build
    Last Post: 02-01-2010, 11:04 PM
  5. Fender Champ Diode Power Supply
    By tyru007 in forum Theory & Design
    Last Post: 10-21-2008, 11:58 PM
Tags for this Thread
