Results 1 to 10 of 10
Thread: Mission amps 5e3 speaker jack wiring help
    New Member
    Oct 2017
    3
    0
    Could anyone do me a huge favor and post a picture of how you wired 2 speaker jacks together on a mission amp 5e3 kit? I cant even remotely wrap my head around the diagram for wiring for the speakers. I have 2 speaker jacks. One of which has 2 tabs for soldering, the other has 3. The Output transformer has 2 leftover wires-- a black one and a blue one. The wiring in the diagram doesn't make sense to me, I only see it picturing a single black wire connecting the 2 jacks to each other and the blue wire going to a different tab and ground, but when I look online I see a bunch of wires going between each jack.
    If you could help me out and post a pic of how you wired the output transformer to the 2 speaker jacks and the 2 speaker jacks together I would GREATLY appreciate it. Thanks!
    May 2010
    Sioux Falls, SD
    6,695
    Received: 1,494/1
    Given: 1,111/1
    17
    Welcome to the place!
    It would help us immensely if you could provide some documentation. Can you upload a schematic and/or layout? Otherwise we are just guessing.
    Dec 2008
    Wernersville, PA
    13,065
    Received: 606/3
    Given: 311/0
    28
    Like this maybe.
    Speaker jacks. Left is 8 ohm, right is 4 ohm.
    May 2010
    Sioux Falls, SD
    6,695
    Received: 1,494/1
    Given: 1,111/1
    17
    Could be, but he says one of the jacks has 3 tabs, so I'm thinking maybe it's a switching jack for internal and external speaker. It also seems there are multiple OT taps, so there could be numerous correct ways to wire it up.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    32,931
    Received: 2,249/7
    55
    Three tabs also suggests the common Fender arrangement of a shorting jack on the main output, with a parallel aux out jack.
    Dec 2008
    Wernersville, PA
    13,065
    Received: 606/3
    Given: 311/0
    28
    If you only are using the Green and Black wires and want to disconnect the internal speaker:
    5e3_schem.pdf
    I found this: Mission Tweedy Deluxe layout:
    5e3_layout.pdf
    It comes down to what the OP wants the circuit to do & what OT he has, doesn't it?
    The three tab jack can be used as a two tab.
    May 2010
    Sioux Falls, SD
    6,695
    Received: 1,494/1
    Given: 1,111/1
    17
    Quote Originally Posted by Jazz P Bass View Post
    ......It comes down to what the OP wants the circuit to do & what OT he has, doesn't it?......
    Yep. And what speaker/cabinet combination is intended. It's a kit, so there are lots of options.
    New Member
    Oct 2017
    3
    0
    Hey guys! Yes, I am new here, and yes, this is my first amp build hence the questions so sorry for being a newb! I do hesitate to post a pic of the schematic as I don't wanna ruffle any feathers with Mission amps. I just figured I'd ask cause I assumed people might be familiar with this specific 5e3 kit here instead of emailing Bruce cause we were building a lot today today and I figured it'd be faster since we're coming close to the end of the build and getting stoked to plug it in soon!
    I am building this 5e3 as a 4x10 combo amp like a bassman, and the speaker load is wired to 8ohms. But I was confused on what the second output jack was for-- an extension cabinet? Would I use the 3 tab jack for the main speakers (I already have a wiring harness utilizing a single input plug) and the 2 tab jack for the extension cab (that I won't even be using, at least for now)?
    Thanks for any help! I hope to contribute to this place more in the future, when I actually have something useful to say haha
    May 2010
    Sioux Falls, SD
    6,695
    Received: 1,494/1
    Given: 1,111/1
    17
    With that configuration, I'd wire it like a typical Fender amp. The two jacks will be paralleled and tip connections hooked to the 8 ohm tap. The grounds will be also connected together and with the OT secondary ground. Then, wire the switch contact of the 3 pin jack to ground also so that when nothing is plugged in the output is grounded. There's a diagram that shows that layout here:
    https://robrobinette.com/images/Guit...dby_layout.png
    The second jack (non-switching) is for an extension cabinet. The main speaker jack must be used first or the output remains shorted via the switch in the jack. This is a typical Fender amp configuration.
    New Member
    Oct 2017
    3
    0
    That website is amazing. Thanks for the link! SO much reading to do on there!
  1. Mission Amps Extension Jack Question
    By Dio666 in forum 5 E 3
    Last Post: 08-11-2010, 06:09 PM
  2. Bruce /Mission Amps 5E3 Q's
    By leucein in forum Mods & Tweaks
    Last Post: 03-21-2007, 07:52 AM
  3. Mission Amps is moving... 5E3 CAB SALE
    By Bruce / Mission Amps in forum Kit Amps
    Last Post: 09-12-2006, 08:51 PM
  4. NEW Mission Amps 5E3 Kits are ready
    Last Post: 08-30-2006, 03:13 AM
  5. NEW Mission Amps 5E3 Kits are ready
    By Bruce / Mission Amps in forum 5 E 3
