Results 1 to 5 of 5
Thread: How to calculate primary impedance of output transistor for class AB push pull stage?
    Old Timer
    Oct 2011
    1,951
    Hi
    Can anyone point me to a link to calculation of the impedance seen by the plate of the power tube in push pull stage of class AB amp. I read RDH4, when in class B region, you see 1/4 or total anode to anode impedance or R=1/4 RL(N1/N2)^2
    But I cannot find an explanation given why R=1/2 RL(N1/N2)^2 when the stage is still in the class A region where both tubes are on.
    Alan
    Supporting Member tubeswell's Avatar
    Feb 2007
    Wellington NZ
    4,141
    Blog Entries
    1
    Received: 54/0
    Given: 16/0
    Quote Originally Posted by Alan0354 View Post
    ... I cannot find an explanation given why R=1/2 RL(N1/N2)^2 when the stage is still in the class A region where both tubes are on.
    When you run two tubes in parallel, you have 2 x the current being driven into the same load (so all other things being equal, you only need 1/2 the load that you would need to get the same voltage swing that you would get with only 1 tube). When both sides of a push-pull output stage are conducting, both sides of the OT primary (each winding end to CT) are conducting, and the active Pr:Sec turns ratio is 2 x what it is than when only one side of the OT primary is conducting.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,413
    Received: 560/15
    Given: 456/13
    Above explanation is correct, this one reaches the same end arriving from a different angle:
    Class AB is a confusing label, so letīs split it into a "pure Class B" section and a "pure Class A" one.
    1) pure Class B: itīs the main component and for maximum power you should order your transformer based on this value.
    In any case, apply the made up example to any datasheet you get:
    suppose you have a 6L6, fed 430V, idle current 30mA ; when fully driven can pass 170mA, plate voltage will drop to almost 50V , just follow the red curve.
    Simple Ohmīs Law, thereīs no mystery to it:
    * Voltage swing: 430V-50V=380V peak
    * current swing: 170mA-30mA=140mA peak
    so optimum plate load impedance:
    * Zp: 380V/0.14A=2700 ohms ... thatīs for a single plate. Za
    Since itīs a push pull, plate to plate impedance Zaa is 4X that (because plate to plate transformer is 2X voltage=4X impedance) so Zaa=10800 ohms. Yup, almost 11k, not a typo.
    Bear with me and youīll understand the full picture.
    2) pure Class A zone: up to 30mA (or whatever idle current you choose): not sure how to draw a graph for this, but the concept is easy to grasp:
    * at idle, both tubes are pulling 30 mA each from the power supply, obviously each at its own end.
    * when one gets a more positive signal from the PI, it will start pulling more current ... which will eventually be fed to the speaker thanks to the transformer.
    So far so good, whatīs expected and intuitive.
    Suppose signal is enough to go from 30mA to 60mA , then positive current variation is 30mA .
    Now to the counter intuitive part, which sounds crazy until it clicks:
    * the other tube will get a more negative signal from the PI, and will start pulling less current from power supply.
    Signal from PI will be same as the other one, just opposite phase.
    Current will *lower* from 30mA to 0 mA, so negative current variation is 30mA.
    Now the "click" part:
    This negative current variation is also passing through the OT, it will be reflected onto the load, but since transformer winding phase is inverted , such current into the speaker will be positive and will add up with current supplied by the opposite tube.
    It is the same as if the other tube had supplied 60mA instead of 30 mA
    * you can say that in the Class A section both push pull tubes act as if they were in parallel and on the same side.
    Again using Ohmīs Law, we know that for 2X current and same voltage swing we have half impedance, so for the Class A section only optimum Zaa (plate to plate impedance) will be 5500 ohms instead of 11000 .
    All this applies to the above graph, with screen voltage 250V.
    Leo (and his imitators) rised screen voltage to chilling 400V and above and in his amps 6L6 can supply WAY more peak current , so optimum plate impedance is way lower, but the "Class A load being half the Class B one" still remains.
    * for finer tuning, you can now assume that "effective" current swing is now 170 mA : 140mA "real" and 30mA "reflected from the other tube" so redo Math using this new value.
    Senior Member Old Tele man's Avatar
    Oct 2007
    Tucson, AZ
    586
    Received: 19/0
    Given: 1/0
    One tube (of two) handles 1/2 of the whole signal, ie: 1/2 of 1/2 is 1/4.
    ...and, I assume that is actually TRANSFORMER and not TRANSISTOR.
    Oct 2015
    153
    Received: 1/0
    nice breakdown here> The Valve Wizard -Push-Pull
  1. Replies: 22
    Last Post: 03-14-2016, 11:56 PM
  2. GU-50 Push-Pull AB OT Impedance/Load Line Questions
    By defaced in forum Theory & Design
    Last Post: 06-04-2015, 06:21 PM
  3. PI values for Class A push-pull
    By lowell in forum Mods & Tweaks
    Last Post: 01-20-2009, 01:21 AM
  4. Replies: 17
    Last Post: 09-11-2008, 07:59 PM
  5. parameters for push pull class A output?
    By swt in forum Theory & Design
    Last Post: 04-29-2007, 05:16 PM
