Results 1 to 28 of 28
Thread: Ibanez TSA5TVR (cute little 5w TV looking amp) with no filament voltage
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    My head is in overload. It looks like this should be a simple fix, but it has me stumped. I've spent way too much time on a cheap amp....it's now a matter of pride and principle.
    This little Ibanez amp is not behaving with the filament voltage. Click image for larger version.
Name:	Ibanez power supply.JPG
ID:	45387 . (Hopefully the power supply schematic was uploaded OK.)
    Here are some clues. The voltage seem OK with the 2 tubes pulled out. When they are plugged in the filament voltage drops (greater drop with both tubes in place). This is supposed to look like a table, so please use your imagination :-)
    ---------------------Tubes out------Tubes In
    D17 Cathode-------9.6 V-----------5.82V
    6V6 pin 2----------9.57 V----------2.00 V
    R54-R60 junction-9.58 V----------2.5 v
    I have replaced Q8 and R60. I have installed my own 2 "test" tubes for 12AX7 and the 6V6 just in case the customers tubes are dragging down the filament.
    (My apologies for not being able to post the complete schematic, but I gave my commitment to the Australian distributor that I wouldn't).
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,627
    Received: 546/1
    So what is the AC voltage at P5, P6, and what does it do under load.
    Do you get the same readings if you measure right at the bridge diodes?
    Measure resistance from P5 to D17 anode. Measure from those points, not just across the fuse. I am doing it to test the fuse and holder, but we want to know if the whole path is good.
    Old Timer
    Cheshire, UK
    1,831
    Received: 54/0
    Given: 34/0
    Do as Enzo suggested first and if that is all OK measure the filament current. Set your meter to DC current and connect it across Q8 C to E. The raw supply only has a 1000u smoothing cap so there will be a lot of ripple which could be why it's sagging to 5.82V. Q8 is running 60mA of base current and it has a min gain of 25 (@ 1A) which implies more than 1.5A filament current. I don't think it has enough gain to drive the (cold?) filaments. The (hot) filament current for a 6V6 + 12AX7 is only 0.75A.
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    Thanks again for your help Enzo. I've carried out your tests and Dave H's. To save repeating, I'll put findings of both recommendations under Daves. :-)
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    First I performed Enzo's tests. Then I measured Q8 BC&E (What is the purpose of Q8? Is it to shut off the filament supply if there is a short on the filament load?). Then I did Dave's tests with some surprising results
    Test.................No Tubes............With tubes
    P5-P6..............8.22VAC..............8.12VAC
    D17-D18..........8.22VAC..............8.09VAC
    R (P5-D17).......0.04 ohm (Fluke 87V zero'd first)
    Q8C................9.67VDC....................5.82VDC
    Q8B................9.52..........................2.46
    Q8E................9.43..........................1.88
    IC-E................1.17mA.....................230mA (6V6 only - the way I had the board precariously perched, I was unable to install the 12AX7)
    Then I noticed something very interesting. Because my Fluke had shunted across the Collector - Emitter junction, the filament was now glowing and 6V6 Filament voltage was 5.26V (that's pretty close to 6.3V :-) ) AND I could hear a pleasing "shhh" out of my speaker. (no signal because of no preamp valve). When I removed my meter the Filament voltage dropped to 2.58v and all joy was lost. Perhaps I should just return the amp with my Fluke attached.
    Should I be suspecting Q8 that I had already replaced? I would take a photo of my abomination of a transistor transplant, but I know I would be cast into the wilderness as being unworthy of sharing the same internet space as these two electrospiritual gurus.
    I await your words of wisdom
    Let it be...
    Chris (the ham)
    30,627
    Received: 546/1
    For me you just verified that good AC was getting to the bridge.
    It sure sounds like the transistor isn't working. But interesting to me that an E-C short there didn't put the full 9v onto the tube heater.
    Are we sure that R54 is 56 ohms?
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    I see what you're saying, Enzo. I checked R54 and R60 again, and their values look fine. I haven't bridged any of the tracks. I might try replacing the TIP31C again just, in case I cooked that somehow. What would be the consequence of me permanently bridging Q8?
    Old Timer
    Cheshire, UK
    1,831
    Received: 54/0
    Given: 34/0
    9V is the peak unloaded voltage. With both tubes in there could be something like 5V p-p ripple. The peak of the ripple will be at 9V and the trough at 4V so the average reading should be around 6.5V but it's reading even lower than that. I'd have to get the scope out to see what the ripple really is. I'd also check C49
    30,627
    Received: 546/1
    It has a thousand mike filter...
    With his base at only a couple volts, his emitter will follow along down there.
    Old Timer
    Cheshire, UK
    1,831
    Received: 54/0
    Given: 34/0
    Quote Originally Posted by christarak View Post
    Yes, replace Q8. I think the circuit is marginal. It will take a high gain Q8 to make it work. Bridging Q8 will put a lot of ripple on the filament supply which may be audible in the speaker. If it is you could try increasing C49 until the filament voltage is 6.3V. My Valve Junior uses a 4,700u cap and it doesn't hum. Going back to the original circuit I think 1000u is too small for C49 try a 4,700u to see if the filament voltage increases. It says it should be 5V on the schematic. Why are they running the filaments at 5V?
    Old Timer
    Cheshire, UK
    1,831
    Received: 54/0
    Given: 34/0
    I don't think 1000u is enough
    Yes the emitter will follow but why is the base at only a couple of volts? It puts 3.4V across the 56ohm which is 60mA of base current. Either Q8 is low gain or C50 is leaky. I wonder if the spiky waveforms are causing confusing DC readings on the Fluke? Could you check with a scope christarak?
  12. #12
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    Thanks Dave. I'll get the scope on it today and watch the ripples. I'll be back (after you get a sleep)
  13. #13
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    Well...there was way more ripple than I expected. I removed the 1000uf and it measured open circuit on the Fluke (I checked the Fluke with a spare 2200uF cap to be sure it can read this. No prob at 2240uF). Sadly this cap is too fat to fit, so its off to the parts store tomorrow morning. Just to be sure I changed Q8, R54 and R60. I might even change C45 just because its annoying me with its whimpy, "why am I even here" looks. What's that you say C50? "What about me?". OK, you're going too.
    Thank you Dave and Enzo. Please check in tomorrow to see if your experience has helped a colleague from the Land of Oz.
    Chris
  14. #14
    Old Timer
    Cheshire, UK
    1,831
    Received: 54/0
    Given: 34/0
    It's not to shut off the supply. It's for ripple reduction. There will be a lot of ripple on the Collector but the ripple on the Base is smoothed by C50 and as Enzo said the Emitter (output) follows the Base.
  15. #15
    30,627
    Received: 546/1
    Oh, I forgot. For this circuit to work down under, you must turn it upside down.
    (Yes, I never get tired of that joke)
    Your 2200 cap may not fit, but you could tack it into the circuit to see if it makes the difference.
  16. #16
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    Thanks Dave. I think I need to do a transistor refresher course. I understand the concept that the Emitter is a 0.6v diode junction away from the Base, and in an amplifier configuration, the Collector provides the current to follow (amplify) the Base signal.
    Here's where I'm a bit foggy. In a switch configuration I thought the Base "facilitated" (actuated) the conduction of what was on the Collector to pass through to the Emitter (less two N-P junctions)...including the ripple. After I first read your and Enzo's comment, I thought it may have something to do with phase cancellation, but if this transistor is acting similar to an Emitter follower then there's no phase inversion.
  17. #17
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    I hear you Enzo. I am fascinated with our weather. In this very same day that we warm up for another summer, you are cooling down from your summer, winter-bound. I love the States and have been there 27 times, and this continual act of magic of our planet never fails to be amaze me. And yes, sometimes I need to hold a schematic upside down to understand it.
  18. #18
    Dec 2008
    Wernersville, PA
    12,347
    Received: 102/0
    Given: 30/0
    Look up "Common Base Transistor".
    That may help.
  19. #19
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    Quote Originally Posted by Jazz P Bass View Post
    That may help.
    Thanks JP. I definitely will
  20. #20
    Old Timer
    Cheshire, UK
    1,831
    Received: 54/0
    Given: 34/0
    Is it working now?
  21. #21
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    Hi Dave. I had a short break to go to the Harley Days Festival this weekend to celebrate my (late) mid-life cliche crisis. I rushed back determined to conquer the little Ibanez amp.
    I had checked the rectifier diodes D17-20 as all OK, but I replaced them anyway. I also replaced C50 on the base of Q8. I upgraded C49 from 1000uF to 2200uF...and up she goes!! The filament is on steady 6.2V (despite the schematic showing 5V). It all works again.
    What was the final cause? I'm putting my money on C50.
    Can I please thank you Dave, and Enzo for your invaluable experience and willingness to help again? And thanks Jazz P Bass for the advice regarding transistor theory. Now that the Ibanez is out of my hair, its' time for a coffee and some light reading.
    Chris
    1 Not allowed! Not allowed!
  22. #22
    Old Timer
    Cheshire, UK
    1,831
    Received: 54/0
    Given: 34/0
    You said the 1000u (C49) measured open circuit. That would do it.
  23. #23
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    You're right, Dave. Thanks mate
  24. #24
    Junior Member
    Aug 2009
    13
    Hey Mr Christarak,.I'm currently working on one.I don't have the schematics only the block diagram to go by.since you have the schematic.Does the schematic matches the block diagram in term of signal path?Thank you in advance.
Name:	Ibanez TSA Block Diagram.jpg
  25. #25
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    I am sorry I can't post the schematic. I have promised the Australian Ibanez distributor that I would keep it confidential. I hope you understand. I made a comparison with the block diagram and the schematic and the block diagram appears to be correct.
  26. #26
    Junior Member
    Aug 2009
    13
    Christarak,
    My apology if my inquiry seen as asking for schematis. No no I totally understood your circumstances. Thank for confirming the block diagram. I think that's plenty helpful before I poke around. Thanks again.
  27. #27
    New Member
    Jun 2018
    1
    Received: 1/0
    Hi Christarak,
    I just came across this post and thought I would belatedly add my 2 cents. I am pretty certain it was the rectifier diodes. I have come across this same problem 3-4 times and each time the diodes tested ok with a meter, but replacing them solved the problem. I always used RL201 diodes (2 amp).
  28. #28
    Aug 2016
    Sydney, Australia
    142
    Received: 5/0
    Given: 42/0
    Quote Originally Posted by amplitech View Post
    Hi Christarak,
    Thanks for that diode recommendation. As far as the final cause, I replaced both the diodes and C50 at the same time so I'm not sure which was the root of the problem. Even though my gut feeling is the cap, I would be unwise to not go with your greater experience in this amp. Thank you for taking the time to share your knowledge.
  1. Filament voltage vs saturation
    By fdesalvo in forum Theory & Design
    Last Post: 10-02-2015, 06:02 PM
  2. Switch output tubes by switching filament voltage?
    By cyclone in forum Theory & Design
    Last Post: 12-25-2014, 10:20 AM
  3. Low Bias Voltage on Crate TV-120
    By RWood in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-30-2009, 06:29 PM
  4. What's the diff. in filament voltage between a 6L6/KT66?
    By steel1953 in forum Mods & Tweaks
    Last Post: 10-23-2006, 07:31 PM
  5. How To Lower Ac Filament Voltage?
    By RANDY in forum Theory & Design
    Last Post: 10-10-2006, 07:09 PM
Tags for this Thread
