Results 1 to 19 of 19
Thread: 67 Fender Princeton Reverb tube/fuse problem
    Dec 2015
    Charleston, WV
    28
    A buddy brought his 100% original (even the tubes) to me last night. Said he was playing and it just died. I'm fairly handy at this sort of thing but not too hip on tube amps. His fuse had blown and I could tell that one of the 6V6s was cooked. So I pulled all of the tubes and put in a correct fuse and it didn't blow. So I told him to bring me some new tubes. Well he bought a whole set of mullards. I put the new tubes in and was getting ready to check the bias and the fuse popped again after about 2 minutes with the amp on. So I put in another fuse and pulled all tubes, hooked it up to my current limiter and the bulb stays dim. Powered the amp down and inserted the 5AR4 rectifier and turned the limiter back on and the bulb stays dim. Next I added the first 6V6 and here's where the trouble lies. With it hooked to the limiter, the bulb stays dim for the 1st 30-45 seconds and then brightens. No signs of arcing on the sockets. I cleaned and re-tensioned them anyway. Filter can cap is in excellent condition and shows what it should. Pin 7 and pin 8 of this tube is right at a full on short showing 0.3 ohms on my Fluke which means my heater pin 7 is 0.3 ohms when I have my lead on the chassis. This isn't right is it?? Any help would be greatly appreciated. Oh and it's the AA764 circuit. Thanks
    Old Timer Leo_Gnardo's Avatar
    Sep 2012
    Dogpatch-on-Hudson
    5,573
    Received: 657/15
    Given: 710/0
    Quote Originally Posted by GrumpyJoe View Post
    No I'd expect chassis ground to filament resistance to read some ultra low resistance IF it's an amp that has a filament center tap going to ground.
    I'm thinkin' your bias supply is suspect. Old bias filter caps often fail. Replace with a 47 to 100 uF cap, 50 to 100V. And make sure the positive end of that cap goes to ground. "It looks OK..." mmmm, no. After 50 years, time for a fresh one. Cheap insurance.
    Dec 2015
    Charleston, WV
    28
    Very true. The can shows the correct capacitance on all sections but I'll go ahead and look for a new one. I pulled the 50uf 50v bias cap and it's reading 60uf. Is that enough to cause a problem?
    Sep 2012
    Dogpatch-on-Hudson
    5,573
    Received: 657/15
    Given: 710/0
    20% over would be considered "in tolerance", otoh on some cap meters leaky caps read over value. For a buck & a quarter cap I'd swap in a new one and know I don't have to worry for another couple decades.
    Lifetime Member Enzo's Avatar
    Lansing, Michigan, USA
    30,937
    Received: 889/5
    It isn't the value that matters, it would be leakage. Your meter might read it with a volt or two. But when it tries to handle 50 volts, it may leak like a sieve.
    If the heaters light up on the tubes, then your filament supply is working.
    Dec 2015
    Charleston, WV
    28
    Never thought about it that way. Yup heaters all light up. I'll change the bias cap and see what happens.
    Jan 2011
    NorCal
    277
    Received: 7/0
    Given: 16/0
    When power tubes fail they often burn the screen resistors.
    http://amps.monkeymatic.com
    30,937
    Received: 889/5
    Before just changing the boas cap, try just measuring bias at the power tube sockets to see if it is way off or going away.
    Dec 2015
    Charleston, WV
    28
    Hey guys sorry it took so long to reply. Been extremely busy. Here are some of my voltage readings for the Princeton.
    Plate voltage is 440vdc
    Bias voltage at pin 5 of V6 is -30.8vdc
    Bias voltage at pin 5 of V5 is -30.5vdc
    Voltage across bias cap is 38.5vdc
    Plate current of V6 is 25.2ma
    Plate current of V5 is 23ma
    Apr 2010
    Burbank, CA
    1,030
    Received: 217/1
    Given: 535/1
    With the 'full set' of Mullard tubes, did that include a new Mullard 5AR4 rectifier tube?
    Dec 2015
    Charleston, WV
    28
    Yes it includes a new 5AR4/gz34.
  12. #12
    Apr 2010
    Burbank, CA
    1,030
    Received: 217/1
    Given: 535/1
    AS the mains furs only blows when you have one or both power tubes installed, I'd be looking at the power supply caps, located in the metal compartment below the chassis. I doubt if the bias cap is the culprit, as so little current is in that circuit (uAmps). This amp being a 1967 vintage, I'd suspect them next, since you have a new rectifier, new power tubes, new preamp tubes.
  13. #13
    Dec 2015
    Charleston, WV
    28
    I've replaced the can filter cap, all electrolytic bypass caps, etc. like I said in the initial post, the fuse only blows after the amp has been powered up for five or so minutes. I'm totally stumped
  14. #14
    Senior Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    818
    Received: 157/1
    Given: 86/0
    Hmmmm.... Do the output tubes show any sign of red-plating? If this is a consistent event, which you've confirmed each time you go through the start up procedure, I would go through the power up procedure again. This time, keep your meter on the grids and see if you loose your grid bias. If it drifts positive or goes open, your amp will start pulling significant current (although the tube usually red-plates as well, but sometimes it's tough to see in full light). I would pay close mind to the socket which had the blown tube, as this could be the reason the tube failed. After taking a good reading of the grid bias, I can understand the logic of crossing that off the list of culprits and not thinking anything of it. But, strange things are afoot at the bench when a piece of gear is under test.
    For example, quick story: I just fixed a Marshall 6100; put all the switching under test; sign wave tested it; played it to test the audio; had put the chassis back in the head and had all but buttoned it up and put it away when I realized that I hadn't double checked the bias on the tubes that the amp came in with. So, all I did was pull the chassis to check the output tube bias and I notice that I was getting a B+ of 510V. This was suspiciously high for your typical Marshall designs. Seemed a lot like a reading of an unloaded secondary, and wouldn't you know, the tubes weren't drawing any current. After the total deflating feeling of thinking you were finally finished with the amp and solved it's issues, I had to go through and find what the hell just happened. Turns out the 470Ω resistor which feeds the screens all of a sudden goes open sometime between when I had just played the thing, put it in the head cab, and took it out to check the bias? How's that for timing. I mean, that job was soooo close to being one of the easy ones.
  15. #15
    Dec 2015
    Charleston, WV
    28
    I'm headed to the shop shortly. I'll do that and post the results. Thanks Soulfetish
  16. #16
    Dec 2008
    Wernersville, PA
    12,452
    Received: 181/2
    Given: 84/0
    Chances are that when the amp goes into overcurrent it will show itself.
    Try powering it up in the dark.
    I have seen all sorts of weird stuff.
    Power trannys, OTs, output tube sockets.
    Try it.
  17. #17
    May 2017
    Memphis, TN
    83
    Received: 7/0
    I'm not sure if this is your problem but I had similar experience retubing and recapping my bandmaster reverb. It ended up being a bad, new JJ GZ34. It kept blowing fuses after being on for some time but never redplated tubes. The only way I found it was one day I saw the tube arc on me during power up. I replaced it with a vintage tube and haven't had a problem since.
  18. #18
    Apr 2010
    Burbank, CA
    1,030
    Received: 217/1
    Given: 535/1
    Quote Originally Posted by tdlunsfo View Post
    Following this line of thought, if you don't have any spare rectifier tubes, such as even a 5U4GB, you could try leaving the new Mullard rectifier tube out, and temporarily installing some 1N4007 rectifier diodes from the HV secondary connections at pins 4 & 6, connecting the cathodes to Pin 8 and see if the same thing happens with this solid state full-wave rectifier.
  19. #19
    Dec 2015
    Charleston, WV
    28
    Sorry it took so long to reply. Turns out that the new rectifier tube is faulty. I had a known to be good Sovtek 5ar4 in my tube drawer and I stuck it in the amp and now the voltages are all where they're supposed to be. Amp is biased and sounds pretty amazing. This is the first time I've dealt with a new tube being faulty. I appreciate all of the responses and help from everybody. I ended up replacing all of the electrolytics and the filter can and the bias cap since it was the stock 50v cap. Amp is super quiet. Thanks again everybody!!!
  1. Replies: 28
    Last Post: 08-14-2015, 05:32 PM
  2. 67 Fender Blackface Super Reverb - Hammond Reverb Tank Replacement Suggestions?
    By Jecarroll7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 04-05-2014, 05:32 PM
  3. Customer returned fixed Fender Princeton 112 reverb: Suddenly fuse keeps blowing
    By kka in forum Maintenance, Troubleshooting & Repair
    Last Post: 05-21-2012, 07:08 AM
  4. Fender Princeton Reverb Reissue w/ hum problem at idle = bad rectifier
    By spiral in forum Maintenance, Troubleshooting & Repair
    Last Post: 01-26-2012, 06:29 AM
  5. Fender princeton reverb transformer problem
    By Doug in forum Maintenance, Troubleshooting & Repair
    Last Post: 11-26-2007, 03:06 AM
