Results 1 to 7 of 7
Thread: 1200S load resistor
    Jun 2012
    160
    1200S load resistor
    Hi folks,
    I have a 1200S here with a BBQ'd load resistor. Can't decipher the band code, but this closest matching schematic suggests a 680ohm 1W across the 16ohm secondary. In this amp it's a 2W CC resistor..
    Sunn Dual Rectifier Amp-1.pdf
    I can't imagine a fault condition, other than no-load, that would cook that resistor.
    The owner plays loud through a custom cabinet, which he says is working fine.
    Lets say the cab, cable, and jacks all check out, what else?
    I thought of flyback voltage, but that would appear on the primary side...
    Any thoughts?
    Old Timer
    Cheshire, UK
    1,834
    Received: 56/0
    Given: 36/0
    Quote Originally Posted by hylaphone View Post
    If it can put out 120W then at full power it can put 120*16/680=2.8W into a 680ohm resistor connected to the 16ohm tap. The resistor needs to be >3W if you play loud.
    Jun 2012
    160
    I should've known Ohm's Law was the culprit
    Thanks, Dave.
    Old Timer
    Cornelius, Oregon
    1,346
    Received: 19/0
    Given: 49/1
    The Sunn 1200S schematics at the Hoffman amp forum show that 680 ohm as a 7 watt resistor.
    Greg
    Sunn Schematics - Tube amp Schematics
    Jun 2012
    160
    Quote Originally Posted by soundmasterg View Post
    Greg
    Indeed, now I wonder if the 1W shown in the schematic I posted is a typo..
    But like I said, this amp had a 2W CC there..
    The ground scheme is goofy, curious to see how noisy this is when I get it fired back up.
    Old Timer J M Fahey's Avatar
    Oct 2007
    Buenos Aires, Argentina
    10,291
    Received: 354/5
    Given: 356/5
    And that amp driven balls to the wall can easily give you some 200W squarewave.
    Now the resistor doesn´t know or care about waveforms, it will happily heat up.
    In that case, the resistor will be asked to dissipate almost 5W, so 7W is minimum.
    Original schematic *might* have asked 10W and one digit was lost along the way.
    Used as a PA, no big deal, voice is (hopefully) used clean, but as soon as you plug a Guitar (or even a Bass) there and rip off, all chips are down.
    Bent Member Chuck H's Avatar
    May 2007
    pacific north west
    13,441
    Received: 424/0
    Given: 463/0
    I can't even count the number of times I've replaced resistors that were under rated for what players do with the amps. Though I'm with Juan on this, Perhaps a 10W spec typo'd to 1W? Still, there are a few cases here and there where a truely vintage amp driven balls out is up to the task but for a couple of resistor ratings.
    "A shot gun delivers a force that exceeds the operational range of most systems, such as pumpkins." Antigua
  1. Configurable Dummy Resistor Load Box for Amp design/repair
    By knausz in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-07-2010, 03:50 AM
  2. Two stages sharing grid load resistor?
    By wizard333 in forum Theory & Design
    Last Post: 12-02-2009, 12:45 AM
  3. Changing the load resistor in the cathode follower
    By Gaz in forum Theory & Design
    Last Post: 08-26-2009, 06:17 PM
  4. What value NFB resistor for 4 ohm spkr load?
    By Humbucker in forum Mods & Tweaks
    Last Post: 01-10-2009, 07:45 PM
  5. Driving a load resistor
    By rf7 in forum Maintenance, Troubleshooting & Repair
    Last Post: 10-11-2007, 07:14 PM
