Results 1 to 6 of 6
Thread: Nashville Tele Setup - Here's a puzzle for you!
    Junior Member
    Mar 2017
    16
    Hey everyone,
    I've been asked to wind a custom strat pickup to be fitted in a telecaster, so that it basically becomes a nashville tele type...
    Now, what I'd like to know is what sort of winding direction and magnet orientation should I have considering I'll have to adapt to the existing tele set... So the existing set is bridge ccw south up and the neck, cw north up. Commonly, one would just take the neck wiring and invert it (bearing in mind to detach the existing ground from the cover) and then my middle would take a CW wind. What about magnet orientation? Obviously, this is for a 5 way switch as on a 3 way, this wouldn't be a problem.
    Also helpful to say, I do not have the tele set with me... this is on the guitar, with the client and a bit far...
    Let em know what you guys think.
    Thanks in advance for your insights
    Cheers
    Mar 2009
    Denmark
    50
    Quote Originally Posted by TeleUser View Post
    Hey everyone,
    Cheers
    I would flip the magnetic polarity on the neck or bridge pickup, depending on what polarity the middle pickup will be, for instance, Bridge (north), middle (South), Neck (north) so you have the best hum canceling solution with the pickup switch in position 2 and 4
    Winding direction is not that important you can just swap the wires on the pickups so you get the phase right, easy to do with a multimeter and a screwdriver.
    Jason Lollar did a nice video on this https://www.youtube.com/watch?v=2lFQzmRvePc
    You can easily swap the magnetic polarity with a magnetizer or a or couple of neo magnets
    Have fun
    Claus Holm Jensen
    ToneOholic! big_teee's Avatar
    Jun 2010
    Mid-South USA
    10,673
    Received: 493/32
    Given: 465/14
    I've done the middle pickup install a few times.
    I also always rewind one of the other pickups.
    Usually I rewind the neck pickup, cause I like a neck wound with 42, to sound more like a strat pickup.
    Also if you keep the start lead grounded, the pickup is quieter.
    So if you keep the bridge pickup CCW S/U, make the neck CCW S/U, and middle CW, N/U.
    Here's pics of my lefty pickup add.
    GL,
    T
ID:	45562   Click image for larger version.
    "Here I come to save the day!"
    That means that Mighty Mouse is on the way!
    (Philip Scheib / Marshall Barer) - circa 1955
    Junior Member
    Mar 2017
    16
    Thanks for the feedback guys...
    Just heard from the builder that this special tele will have a gibson toggle switch so, no issues...
    Thanks again
    Senior Member LtKojak's Avatar
    Feb 2008
    Milano, Italy
    980
    Received: 13/3
    Quote Originally Posted by big_teee View Post
    Hey T, how much wire can you get into that tele neck p'up using #42?
    Inquiring minds would like to know.
    Pepe aka Lt. Kojak
    Milano, Italy
    Jun 2010
    Mid-South USA
    10,673
    Received: 493/32
    Given: 465/14
    I like around 7700-7900 turns of SPN with close to 1/2 inch between the flats.
    With a metal cover I charge A5s to full gauss.
    Leaving a little extra magnet out the bottom doesn't hurt either.
    Give it a try!
    T
  1. Inductance Puzzle
    By Jason Robitaille in forum Beginner/ Hobbyist
    Last Post: 04-11-2017, 03:34 AM
  2. Crate GX-212 power amp puzzle
    By DGstrat in forum Maintenance, Troubleshooting & Repair
    Last Post: 06-06-2016, 07:22 AM
  3. Super Switch Nashville Tele question??
    By retrorod in forum Guitar Tech
    Last Post: 02-12-2014, 02:27 AM
  4. 4 way Tele Setup?
    By Edward R in forum Pickup Makers
    Last Post: 07-05-2008, 04:02 PM
  5. Deluxe Reverb RI Bias Puzzle
    By jcollins in forum Maintenance, Troubleshooting & Repair
    Last Post: 02-12-2008, 09:51 PM
