Results 1 to 11 of 11
Thread: JJ 6V6s spice model
    New Member
    Nov 2017
    3
    JJ 6V6s spice model
    Hi everyone,
    I decided to mix my two passions (electronics and music) and to design my own 5W SE guitar amp.
    In order to ensure my calculation is right about bias, distortion and gain, I began spice simulations of my preamp/tone stages based on JJ ECC83.
    The next step is to simulate the output stage, and I decided to use the JJ 6V6s pentode. However, after hours of deep search on tens of websites and forums, I couldn't find any spice simulation model for this tube...
    I was wondering if anyone did create its own spice model for this tube, and would be ok to share it ?
    Thank you by advance for your help...!
    Jun 2006
    272
    Don't know any 6V6 models, sorry!
    However, simulations have limited value for designing something as simple as a SE output stage. I think you are better off building it and experimenting, going by your ears rather than simulation.
    Dec 2009
    Devon, UK
    3,013
    Received: 285/1
    Given: 271/1
    Agree with the previous comment.
    You won't find any model that is specific to a JJ 6V6, the tolerances far exceed the differences between types. This is the best model that I am aware of:
    Code:
    .SUBCKT 6V6GT 1 2 3 4 ; A G2 G1 C;
    *      Extract V1.980
    * Model created:  7-Jun-2014
    * NOTE: LOG(x) is base e LOG or natural logarithm.
    * For some Spice versions, e.g. MicroCap, this has to be changed to LN(x).
    X1 1 2 3 4 BTetrodeDE  MU= 10.56 EX=1.306 kG1= 609.8 KP=  47.9 kVB = 2171.5 kG2=17267.3
    +Sc=.81E-01 ap=  .013 w=    18. nu=   .92 lam=     5.7
    + Ookg1mOokG2=.158E-02 Aokg1=.57E-06 alkg1palskg2=.158E-02 be=  .068 als= 18.72 RGI=2000
    + CCG1=9.0P  CCG2 = 0.0p CPG1 = 0.7p  CG1G2 = 0.0p CCP=7.5P  ;
    .ENDS
    .SUBCKT BTetrodeDE 1 2 3 4; A G2 G1 C
    RE1  7 0  1MEG    ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
    E1 7 0 VALUE=
    +{V(2,4)/KP*LOG(1+EXP(KP*(1/MU+V(3,4)/SQRT(KVB+V(2,4)*V(2,4)))))}
    E2   8 0 VALUE = {Ookg1mOokG2 + Aokg1*V(1,4) - alkg1palskg2*Exp(-be*V(1,4)*SQRT(be*V(1,4)))}
    E3   9 0 VALUE = {Sc/kG2*V(1,4)*(1+tanh(-ap*(V(1,4)-V(2,4)/lam+w+nu*V(3,4))))}
    G1   1 4 VALUE = {0.5*(PWR(V(7),EX)+PWRS(V(7),EX))*(V(8)-V(9))}
    G2   2 4 VALUE = {0.5*(PWR(V(7),EX)+PWRS(V(7),EX))/KG2 *(1+als*Exp(-be*V(1,4) * SQRT(be*V(1,4))))}
    RCP  1 4  1G      ; FOR CONVERGENCE    A  - C
    C1   3 4  {CCG1}   ; CATHODE-GRID 1    C  - G1
    C4   2 4  {CCG2}   ; CATHODE-GRID 2    C  - G2
    C5   2 3  {CG1G2}   ; Grid 1-GRID 2    G1  - G2
    C2   1 3  {CPG1}  ; GRID 1-PLATE    G1 - A
    C3   1 4  {CCP}   ; CATHODE-PLATE    A  - C
    R1   3 5  {RGI}   ; FOR GRID CURRENT    G1 - 5
    D3   5 4  DX      ; FOR GRID CURRENT    5  - C
    .MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
    .ENDS BTetrodeDE
    New Member
    Nov 2017
    3
    Wow, I didn’t expect so quick answers thank you very much !
    Actually, I’m a signal and power integrity engineer on multi-GHz digital bobards, and simulation is in my job’s genetics
    Still, I completely understand your argument about listening-based design. As I won’t order my design’s parts before a few months I wanted to anticipate the behaviour as much as I could in order to make time run faster
    I’ll give a try to nickb’s model just to avoid big calculation mistakes.
    Thank you again !
    Supporting Member jazbo8's Avatar
    Jun 2011
    599
    Received: 3/0
    6V6S Spice Model
    Rename the attachment as .inc
    Attached Files Attached Files
    New Member
    Nov 2017
    3
    Perfect, thank you VERY much jazbo8
    Even if my ears will be the final judge, I will be able to quench my thirst of simulation !
    Dec 2009
    Devon, UK
    3,013
    Received: 285/1
    Given: 271/1
    Here is a comparison of the two models ( Derk Reefman and Ayumi Nakabayashi):
Name:	6V6 sweep.JPG
    The screen current for the Ayumi Nakabayashi model is very high, the datasheet states Ig2=4.5mA for Va=Vs=250 and Vg=-12.5. Also it is starts to reduce at very low plate voltages. The plate current plot has a discontinuity and does not show the typical beam tetrode kink. The Derk model is closer to reality, IMHO.
    Member bea's Avatar
    Dec 2010
    Germany, FRA
    227
    Received: 2/0
    Given: 1/0
    Hard to tell, actually. Simple reason: lack of curves for the 6V6GT.
    But here a set of curves for the 6V6GTA: http://www.mif.pg.gda.pl/homepages/f...5/6/6V6GTA.pdf
    I'm a bit tired to do an exact comparison - but qualitatively that one appears to be more similar to the Ayumi model. Which mainly demonstrates the importance of knowing the actual reference source for the model...
    Senior Member SoulFetish's Avatar
    Jan 2016
    Massachusetts
    823
    Received: 161/1
    Given: 88/0
    If you'll forgive my ignorance and indulge me for a moment – Can these models be used within spice to plot operating curves and output graphical data? If so, I would think we could compare these against actual data curves obtained by a µtracer (as an example) as one method of testing accuracy.
    But, then again, perhaps you would find the tolerances between individual 6L6 operation to be great enough that it trivializes any differences between these models.
    ...of course, I could always learn how to use spice and see for myself
    Dec 2009
    Devon, UK
    3,013
    Received: 285/1
    Given: 271/1
    Quote Originally Posted by SoulFetish View Post
    The Derk model above was obtained by curve tracing on a uTrcaer and then best fitting the model to that data.
    Jan 2016
    Massachusetts
    823
    Received: 161/1
    Given: 88/0
    Quote Originally Posted by nickb View Post
    Well... that was good thinkin' then. I sure wish I thought of that.
  1. JJ 6v6s spare pins.
    By wozt in forum Tubes (Valves)
    Last Post: 04-18-2015, 02:02 PM
  2. Problem with my SPICE model?
    By jul059 in forum Theory & Design
    Last Post: 11-07-2013, 01:52 PM
  3. Replies: 26
    Last Post: 06-12-2013, 07:58 PM
  4. LM3886 Spice model
    By lowell in forum Theory & Design
    Last Post: 09-27-2012, 12:51 PM
  5. JJ 6V6s sturdiness
    By txstrat in forum Tubes (Valves)
    Last Post: 04-20-2010, 08:49 PM
