Hi everyone,
meanwhile i am trying to learn a bit how to work with spice.
The project shown is based on a kit which i never got to work correctly (well, meanwhile it should, but since that build i'd like to avoid cathode biased PP stages with a common cathode resistor ... guess what happened ;-)).
Here the initial circuitry:
And here my ideas.
You might imagine something inspired by a Hiwatt preamp stage or the preamp i designed for my G2000, maybe as a low power bass amp for rehearsals and sessions in the final run.
In my eyes that circuitry is ready to be built. The output stage is closely modeled to the output stage of the Echolette M40, which is an ancient PA amp with 4 EL84 in class B.
Independent on that i would like to come a bit closer to a more realistic modeling of the stability of the feedback loop. And that requires better tube models and even more important more realistic models of the output transformer.
Another aspect important to me is the modeling (and limiting...) of the grid currents on the screen grids in the case of tube saturation...
In a further step i would like to extend everything to the case of EL34 PP class B at 750 V (i have the parts lying around and could also measure and more important test the (old) transformer set for sanity...)
Any suggestions, mostly on the transformer measurements? I have the transformers at hand and could do measurements to the degree my limited equipment permits (cheap function generator, oscilloscope, two multimeters).
(BTW: and which tube models would simulate these special aspects at least half way realistic? At present i am using Koren based models modified by someone else with data from µ-Trace measurements, which seem to be pretty good in the LoV regime.
And here my ideas.
