I take my SWR California Blonde acoustic guitar amplifier to a gig last night. Everything is fine until I tilt the amp back at about a 45 degree angle. Then I start getting crackling noises. I check the instrument cable and power cable and switch them out. When the amp is vertical it works fine, but once it is tilted back it acts up. The overload LED even blinks.
I tear it apart today and check for loose speaker wires. I also do the chopstick tap on components to isolate the faulty item. I kind of suspect a loose wire or cold solder joint. Well I can't seem to get it to act up.
Any ideas?
Any ideas?
